POV-Ray : Newsgroups : povray.newusers : Local Co-ordinates Server Time
23 Dec 2025 06:47:15 EST (-0500)
  Local Co-ordinates (Message 1 to 7 of 7)
Subject: Local Co-ordinates
Date: 19 Sep 2002 18:15:11
Message: <web.3d8a4bb0ae2b17b330411fcf0@news.povray.org>
Is there a way to change the local co-ordinates of an object or grouped
objects so that when you rotate that object it moves around that point. Like
how you can do it in Moray. But when I use the pov. scene Moray emits it
hasn't converted the co-ordinates.
Thank you,
          your help will be greatly appreciated.
Subject: Re: Local Co-ordinates
Date: 19 Sep 2002 18:37:26
Message: <3d8a51a6$1@news.povray.org>
"insomniac" <lee### [at] hotmailcom> schrieb im Newsbeitrag
news:web.3d8a4bb0ae2b17b330411fcf0@news.povray.org
> grouped objects so that when you rotate that object it moves around
> that point. Like how you can do it in Moray. But when I use the pov.
> scene Moray emits it hasn't converted the co-ordinates.
> Thank you,
You have to move your object into the origin, rotate it, and move it back.
Maybe a little macro will do:
#macro Rotate_around (RotVector, Position)
    translate -Position
    rotate RotVector
    translate Position
Maybe such a macro is already in the includes which are shipped with POV-Ray,
but I don't know.
Kalle
Date: 19 Sep 2002 19:15:06
Message: <web.3d8a598449510b1030411fcf0@news.povray.org>
>    translate -Position
>    rotate RotVector
>    translate Position
>#end
>but I don't know.
>Kalle
Hello Kalle,
            I've only been using povray a few weeks and don't know very
much,
could you please elaborate "move your object into the origin, rotate it, and
move it back" how do you move it into the origin? I'm sorry, i'm still
learning all the ins and outs. Thank you for your response.
Date: 19 Sep 2002 19:50:02
Message: <web.3d8a618e49510b104afeda730@news.povray.org>
What i've got is a grouped object (a Table Lamp), it rotates around the
world coordinates and I want it to rotate around the edge base of the lamp
so I can animate it falling over.
Date: 19 Sep 2002 20:08:48
Message: <3d8a66e1@news.povray.org>
translate -edge_base_of_the_lamp
rotate whatever
translate edge_base_of_the_lamp
Date: 19 Sep 2002 21:32:07
Message: <B9B03842.4D4C%fidel.viegas@artrecognition.co.uk>
> Hello Kalle,
> much,
Suppose your object is place at <4, 5, 1>. What you do is this
object {
  yourobject
  translate -<4, 5, 1> // place the object at the origin <0, 0, 0>
  rotate <45, 0, 0> // just an example
  translate <4, 5, 1> // move the object back to where it was
Basicallly, you first move the object to the origin, by translating it by
the negation of its current position. You then rotate it, and after rotating
it, you just move the object to where it was before by translating the same
amount without the '-' sign.
Hope that helps.
Fidel.
Date: 19 Sep 2002 22:25:04
Message: <web.3d8a86a349510b10dd2c03fb0@news.povray.org>
>object {
>  yourobject
>Hope that helps.
>Fidel.
Hey that worked! Thanks a lot for your help.
insomniac.
