POV-Ray : Newsgroups : povray.newusers : Using different image maps with different clock values Server Time
21 Nov 2025 16:33:58 EST (-0500)
  Using different image maps with different clock values (Message 1 to 7 of 7)
Subject: Using different image maps with different clock values
Date: 22 Aug 2002 12:10:04
Message: <web.3d650b9da4e8de9e179062da0@news.povray.org>
I know how to define an image map for an object, but what if I want to use
different image maps (seperate, pre-rendered scene) while the clock is
running? How could I change the reference automatically?
N.
Subject: Re: Using different image maps with different clock values
Date: 22 Aug 2002 12:19:03
Message: <3d650ef7$1@news.povray.org>
"nathan_2002" <nat### [at] excitecom> wrote in message
news:web.3d650b9da4e8de9e179062da0@news.povray.org...
Not tested, but two ways I can think of:
1. Use a case statement
2. Use filenames that can be referenced from the clock value, e.g. 1.bmp, 2.bmp
Date: 22 Aug 2002 13:14:06
Message: <3d651bde@news.povray.org>
  Another solution, when you have file names without consecutive numbers,
is to put all the file names in an array and the index this array with
something like int((dimensions_size(Images,1)-1)*clock+.5)
Date: 22 Aug 2002 21:43:03
Message: <3d659327$1@news.povray.org>
This code looks for a sequence of images labeled "red001.tga" through
"red390.tga" while the clock ticks. You can then use Pigmap in any pigment
statement (or as a function in an isosurface if you want to build an object
with it; sorry, forget that):
 #declare Pigmap = pigment {
  image_map {tga concat("e:\\red\\red", str(clock*390,-3,0), ".tga")
    map_type  2  interpolate  2 } }
So maybe number the images sequentially? How many are there and how often do
you want the image to change?
d.
news:3d651bde@news.povray.org...
M()}}
Warp -
Date: 29 Aug 2002 12:15:07
Message: <web.3d6e475fbc6d480690cc6b70@news.povray.org>
So then it would be somthing like...
> #declare Scene = pigment {
>  image_map {png concat("d:\\povray\\book\\scene", str(clock*180/.75,-3,0), ".png")
The embeded scene would have 180 frames, I guess the clock wouldn't matter
after rendered.
the frame scene has the following properties:
+ki0 +kf0.75 +kfi1 +kff180
so in the "str(clock*180/.75,-3,0)", what do the -3 and 0 mean?
I'd try it myself but my computer only runs at 200Mhz...
N.
Date: 30 Aug 2002 22:18:56
Message: <3d702790@news.povray.org>
It has to do with the number of zeros tat POV should "pad" the file name
with. Can't remember the exact location in the docs on that one but -3
should work for a group that is numbered up to 180...
D.
news:web.3d6e475fbc6d480690cc6b70@news.povray.org...
do
> after rendered.
> N.
Date: 31 Aug 2002 01:01:51
Message: <3D7068FF.3B963D97@joplin.com>
I also used pigment average, if you want to fade from one image to another.
Have Fun!
