POV-Ray : Newsgroups : povray.newusers : Dumb Blonde requires your help Server Time
10 Apr 2026 16:12:34 EDT (-0400)
  Dumb Blonde requires your help (Message 1 to 4 of 4)
Subject: Dumb Blonde requires your help
Date: 20 Aug 2002 17:40:10
Message: <web.3d62b6ee2ffea3e6ee5540370@news.povray.org>
Actually, I'm not that dumb!  I'm a Maths undergraduate writing a report on
heat transfer.  I need a fairly simple illustration of a tea urn
(commercial catering water boiler).
The tea urn is made of 1 layer of stainless steel and then 1 layer of
polypropylene.
I tried to draw some cylinders but they seem to have zero width.  I could
not find a way to draw cylinders with a substantial width.
Can anyone please help?
Kind regards,
Jenny Page
email: jen### [at] hotmailcom
Subject: Re: Dumb Blonde requires your help
Date: 20 Aug 2002 18:07:05
Message: <3D62BD1B.5020409@global2000.net>
Look up difference in the povray documentation.
difference {
    cylinder
       <0,0,0>,
       <0,1,0>,
       1
       pigment { color rgb <1,0,0> } //red
    cylinder
       <0,0.5,0>,
       <0,1.1,0>,
       0.5
       pigment { color rgb <0,0,1> } //blue
This code would make a cylinder with a cylinderial piece cut out of it.
  The second one is what is cut out of the first one.  You can have as
many shapes cut out of the first shape.
If you need more help you can always ask.
Brendan
Date: 20 Aug 2002 18:10:02
Message: <3d62be3a$1@news.povray.org>
did you specify a radius? it comes right after the second coordinate
"JennyPage" <jen### [at] hotmailcom> wrote in message
news:web.3d62b6ee2ffea3e6ee5540370@news.povray.org...
on
> polypropylene.
> Kind regards,
> Jenny Page
Date: 20 Aug 2002 18:14:42
Message: <chrishuff-E3558D.17001520082002@netplex.aussie.org>
In article <web.3d62b6ee2ffea3e6ee5540370@news.povray.org>,
> polypropylene.
By "width", do you mean thickness of the cylinder wall?
Shape surfaces are infinitely thin in POV, if you are using cylinders
with "open" or "clipped_by" to remove the end caps you will get a single
surface instead of a thick sheet. If you want a tube with some thickness
to the walls, you should use a CSG difference of two cylinders:
difference {
    cylinder {< 0, 0, 0>, < 0, 1, 0>, 0.5}//the main cylinder
    //Cut out the center to leave a tube
    cylinder {< 0,-0.001, 0>, < 0, 1.001, 0>, 0.4}
Notice that the end points are slightly outside the main cylinder, this
is to avoid precision errors where the surfaces would coincide.
If the polypropylene is thin enough that you can't see its thickness,
you could get away with just texturing the inside differently. In that
case, just give the first cylinder a stainless steel texture, and the
second cylinder a polypropylene texture.
http://tag.povray.org/
