POV-Ray : Newsgroups : povray.newusers : How can I print a vector to the screen? Server Time
18 Jan 2026 21:40:17 EST (-0500)
  How can I print a vector to the screen? (Message 1 to 10 of 12)
Subject: How can I print a vector to the screen?
Date: 14 Apr 2002 18:35:55
Message: <slrnabk0up.tm8.steve@zero-pps.localdomain>
Is there a way to print a vector using #debug?  And if so could someone
please give an example?
This is only part of my current problem, I'm trying to center text but
there is NO documentation on this, though in both the POV docs and in the
VFAQ this is listed as a question that is answered - but the question is
not answered it just says use min and max_extent.
I know quit a bit about programming and am able to work most things out, but
after three hours of going through the documentation I can't come up with
a working solution for either of the problems posted above, I'd be grateful
if someone could post an example of how to center an object.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Subject: Re: How can I print a vector to the screen?
Date: 14 Apr 2002 21:54:34
Message: <chrishuff-9C2955.20563414042002@netplex.aussie.org>
In article <slr### [at] zero-ppslocaldomain>,
The #debug statement only takes strings, so you will need to convert the
vector to a string first. Since you seem to be using POV-Ray 3.5, look
up the documentation for the vstr() function.
The answer is to use min_extent() and max_extent(). ;-)
Once you have the coordinates of each corner of the bounding box, it is
very simple to translate it so it is centered over the origin or any
other desired point. Just find the center and translate by -CenterPos.
Or you could use the standard macro for this: Center_Trans() in
transforms.inc.
Date: 15 Apr 2002 01:11:37
Message: <3CBA6181.40902@web.de>
Try this:
// Simply "returns" a vector in a string in POV-Ray notation
#macro v_string (V)
  concat ("<", str (V.x, 0, 4),", ", str (V.y, 0, 4),", ", str (V.z, 0,
4),">")
#declare Wanna_see_this_vector = <2, 0.1, 12.5>;
// Should print <2, 0.1, 12.5> to the debug output
#debug v_string (Wanna_see_this_vector)
Date: 15 Apr 2002 08:01:48
Message: <3cbac12c@news.povray.org>
Sebastian H. <seb### [at] webde> wrote:
> #macro v_string (V)
> 4),">")
> #end
  Why not use vstr() instead?
Date: 15 Apr 2002 08:35:28
Message: <3cbac910@news.povray.org>
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
It's worth noting that "centering an object" rarely makes sense, since most
things don't have a centre in human terms, and nothing has a centre in POV
terms. Using the bounding box is a workaround, but, for example, the centre of
an L-shaped shape, according to its bounding box, is going to be an empty area
(half way and half way along).
I realise that this isn't really an issue when thinking about a text-string, but
conceptually you can get very stuck if you think of POV objects as having a
centre (generally because, if you decide that objects have a centre, then you
expect transformations to work with those centres).
Date: 15 Apr 2002 08:43:56
Message: <slrnable71.vmr.steve@zero-pps.localdomain>
Thanks Chris, I'm suffereing severely as there isn't a text version of the
3.5 docs available yet (or wasn't last night).
> transforms.inc.
Thanks, I'll have a go at this.  Now that I can #debug vectors I'll be
able to sort something out.
Date: 15 Apr 2002 08:43:57
Message: <slrnablebn.vmr.steve@zero-pps.localdomain>
> Try this:
> #macro v_string (V)
> 4),">")
> #end
Thanks that syntax is what I needed.
Thanks again, I may incorporate soemthing liek this.  I just hope my
3.5 hasn't expired on me.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 15 Apr 2002 15:16:06
Message: <3CBB276E.1080801@web.de>
This is what happened to me this morning when I wanted to trace a little
  animation while stying at university :-)))
Sebastian H.
Date: 15 Apr 2002 15:30:57
Message: <3CBB2AE9.80205@web.de>
>>#macro v_string (V)
>>4),">")
>>#end
You're right vstr() would be a better (!!?) solution but since this is a
new user group I thought it won't hurt to give an example of how to use
the concat () and str () which are very essencial in my thoughts (I use
them a lot).
(Beside I wrote this little macro just yesterday for myself and had
somwhere in mind that there exists a vstr () function which takes soooo
many args :-).)
Sebastian H.
(Oh dear, I have to improve my english...)
Date: 15 Apr 2002 17:21:54
Message: <3cbb4472@news.povray.org>
> many args :-).)
  You can use vstr() in your macro.
