POV-Ray : Newsgroups : povray.newusers : How can I print a vector to the screen? Server Time
9 Jan 2026 06:27:32 EST (-0500)
  How can I print a vector to the screen? (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: How can I print a vector to the screen?
Date: 15 Apr 2002 01:11:37
Message: <3CBA6181.40902@web.de>
Steve wrote:
> Is there a way to print a vector using #debug?  And if so could someone
> please give an example?
Try this:
// Simply "returns" a vector in a string in POV-Ray notation
#macro v_string (V)
  concat ("<", str (V.x, 0, 4),", ", str (V.y, 0, 4),", ", str (V.z, 0,
4),">")
#declare Wanna_see_this_vector = <2, 0.1, 12.5>;
// Should print <2, 0.1, 12.5> to the debug output
#debug v_string (Wanna_see_this_vector)
Date: 15 Apr 2002 08:01:48
Message: <3cbac12c@news.povray.org>
Sebastian H. <seb### [at] webde> wrote:
> #macro v_string (V)
> 4),">")
> #end
  Why not use vstr() instead?
Date: 15 Apr 2002 08:35:28
Message: <3cbac910@news.povray.org>
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
> a working solution for either of the problems posted above, I'd be grateful
> if someone could post an example of how to center an object.
It's worth noting that "centering an object" rarely makes sense, since most
things don't have a centre in human terms, and nothing has a centre in POV
terms. Using the bounding box is a workaround, but, for example, the centre of
an L-shaped shape, according to its bounding box, is going to be an empty area
(half way and half way along).
I realise that this isn't really an issue when thinking about a text-string, but
conceptually you can get very stuck if you think of POV objects as having a
centre (generally because, if you decide that objects have a centre, then you
expect transformations to work with those centres).
Date: 15 Apr 2002 08:43:56
Message: <slrnable71.vmr.steve@zero-pps.localdomain>
On Sun, 14 Apr 2002 20:56:34 -0500, Christopher James Huff wrote:
> In article <slr### [at] zero-ppslocaldomain>,
> The #debug statement only takes strings, so you will need to convert the
> vector to a string first. Since you seem to be using POV-Ray 3.5, look
> up the documentation for the vstr() function.
Thanks Chris, I'm suffereing severely as there isn't a text version of the
3.5 docs available yet (or wasn't last night).
>> This is only part of my current problem, I'm trying to center text but
>> there is NO documentation on this, though in both the POV docs and in the
>> VFAQ this is listed as a question that is answered - but the question is
>> not answered it just says use min and max_extent.
> The answer is to use min_extent() and max_extent(). ;-)
> Once you have the coordinates of each corner of the bounding box, it is
> very simple to translate it so it is centered over the origin or any
> other desired point. Just find the center and translate by -CenterPos.
> Or you could use the standard macro for this: Center_Trans() in
> transforms.inc.
Thanks, I'll have a go at this.  Now that I can #debug vectors I'll be
able to sort something out.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 15 Apr 2002 08:43:57
Message: <slrnablebn.vmr.steve@zero-pps.localdomain>
> Try this:
> #macro v_string (V)
> 4),">")
> #end
Thanks that syntax is what I needed.
Thanks again, I may incorporate soemthing liek this.  I just hope my
3.5 hasn't expired on me.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 15 Apr 2002 15:16:06
Message: <3CBB276E.1080801@web.de>
This is what happened to me this morning when I wanted to trace a little
  animation while stying at university :-)))
Sebastian H.
Date: 15 Apr 2002 15:30:57
Message: <3CBB2AE9.80205@web.de>
>>#macro v_string (V)
>>4),">")
>>#end
You're right vstr() would be a better (!!?) solution but since this is a
new user group I thought it won't hurt to give an example of how to use
the concat () and str () which are very essencial in my thoughts (I use
them a lot).
(Beside I wrote this little macro just yesterday for myself and had
somwhere in mind that there exists a vstr () function which takes soooo
many args :-).)
Sebastian H.
(Oh dear, I have to improve my english...)
Date: 15 Apr 2002 17:21:54
Message: <3cbb4472@news.povray.org>
> many args :-).)
  You can use vstr() in your macro.
Date: 15 Apr 2002 18:42:00
Message: <chrishuff-F95170.17440315042002@netplex.aussie.org>
In article <3cbb4472@news.povray.org>, Warp <war### [at] tagpovrayorg>
> > many args :-).)
And the strings.inc include file has several shortcut macros, including
versions that take only one argument, the vector to be converted.
Date: 24 Apr 2002 11:08:50
Message: <3cc6ca82@news.povray.org>
> I'd be grateful if someone could post an example of how to center an
object.
Use the Center_Object() macro in "shapes.inc"
The syntax is: Center_Object(object_to_center, axis_to_center_on)
Axis can be combined, if you want to center the object at y and z axis, use
y+z .
#include "shapes.inc"
#declare Object = text{ttf "arial.ttf" "Look! I'm centered!!" 0.5,0 pigment
{rgb 1}}
Center_Object(Object,x+y+z)
This should do the trick..
_.-=^=-._.-=[ Peter ]=-._.-=^=-._
  _.-=[ http://hertel.no/peter ]=-._
