POV-Ray : Newsgroups : povray.newusers : Only take a minute - 1 day later, math question Server Time
11 Apr 2026 01:55:38 EDT (-0400)
  Only take a minute - 1 day later, math question (Message 1 to 4 of 4)
Subject: Only take a minute - 1 day later, math question
Date: 30 Jan 2004 06:23:07
Message: <opr2k5x2xmp4ukzs@news.povray.org>
I'm trying to create a crescent moon shape as per the code below, which
took a bit longer than I thought and still has a couple of bugs:) I ran up
against a interesting problem I'll try and explain it in two dimensions:
A circle with radius MainRadius enclosing a circle of MinorRadius both at
0 centres.
Create a new circle with radius NewRadius such that when moved *from*
<-NewRadius,0> *to* <-MinorRadius, 0> points on the circumference pass
through points: <-MinorRadius,0>(obviously), <0,MajorRadius>,
<0,-MajorRadius>.
In the instance below I happen to know NewRadius is approx 3.25, but I
wondered if anyone knew a way of fixing this exactly?
I await huge amounts of unintelligble math :)
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
<code>
global_settings {
assumed_gamma 1.0
photons {
count 20000
media 200
autostop 0
jitter .4
radiosity {
pretrace_start 0.08
pretrace_end   0.02
nearest_count 10
error_bound 1
low_error_factor 0.1
gray_threshold 0.25
minimum_reuse 0.02
always_sample off
adc_bailout 0.01
light_source{<0,10,10> rgb 1}
#declare NurseGreen=pigment{rgb <102/255,204/255,153/255>};
#declare NurseBlue=pigment{rgb <0,102/255,204/255>};
#declare BackGreen=rgb <204/255,1,1>;
background{color BackGreen}
#declare MainWidth = 3.15;
#declare Depth = 0.7;
#declare MainAngle = degrees(atan2(Depth,(MainWidth-Depth)));
#declare LengthofSide=sqrt((Depth*Depth)*2);
#declare SecondDegrees= 45;
#declare SecondAngle=SecondDegrees-MainAngle;
#declare SecondHeight=LengthofSide*sin(radians(SecondAngle));
#declare SecondWidth=LengthofSide*cos(radians(SecondAngle));
camera{
location <-(MainWidth-Depth),0,-7>
look_at <-(MainWidth-Depth),0,0>
#declare FirstCrescent=
cone{0,MainWidth,<0,0,-Depth>,(MainWidth-Depth) open
clipped_by {box{<7,7,0>,<-7,-7,-2> rotate -y*MainAngle inverse}}}
#declare SecondCrescent=
cone{0,(3.25-SecondWidth),<0,0,-SecondHeight>,3.25 open translate
<3.25,0,SecondHeight> rotate -y*MainAngle translate <-2.45,0,-Depth>
clipped_by{box{<5,5,0>,<-5,-5,2> inverse}}}
object{FirstCrescent pigment{NurseGreen} finish{ambient 0}}
object{SecondCrescent pigment{NurseBlue} finish{ambient 0}}
</code>
Subject: Managed to find the math but still a slight annoyance
Date: 30 Jan 2004 08:29:42
Message: <opr2lbsxeqp4ukzs@news.povray.org>
Well I managed to find the math and even seem to have managed to convert
it to POV correctly :),  however it seems to calculate y incorrectly; as I
know it's 0 not a problem but it is bugging me.
<code>
//All the Math
#declare x1=0;
#declare y1=-MainWidth;
#declare x2=-(MainWidth-Depth);
#declare y2=0;
#declare x3=0;
#declare y3=MainWidth;
#declare ma=(y2-y1)/(x2-x1);
#declare mb=(y3-y2)/(x3-x2);
#declare myx=((ma*mb*(y1-y3))+(mb*(x1+x2))-(ma*(x2+x3)))/(2*(mb-ma));
#declare myy=(ma*(myx-x1))+y1;
#declare NewRadius=(MainWidth-Depth)+myx;
#debug concat("ma is:",str(ma,5,-1),"\n")
#debug concat("mb is:",str(ma,5,-1),"\n")
#debug concat("myx is:",str(myx,5,-1),"\n")
#debug concat("myy is:",str(myy,5,-1),"\n")
#debug concat("NewRadius is:",str(NewRadius,5,-1),"\n")
</code>
and changed
<code>
difference{
cone{0,MainWidth,<0,0,-Depth>,(MainWidth-Depth) open}
cylinder{<myx,0,1>,<myx,0,-1>,NewRadius}
</code>
Which removes the overlap from the first code and seems to be okay, handy
bit of math if the y worked.
Phil
Subject: Re: Only take a minute - 1 day later, math question
Date: 30 Jan 2004 15:19:01
Message: <cjameshuff-EFD455.15190130012004@news.povray.org>
In article <opr2k5x2xmp4ukzs@news.povray.org>,
Well, a crescent moon is just a half lit sphere. The outline is a
circle, and the shadow line an ellipse. In the real world there are
things like perspective to consider...you can probably ignore those
here, though you haven't said what you were using it for. I'm not really
sure what you're doing with those cones, or what kind of 3D shape you're
looking for...just render a half-dark sphere if you want an actual
crescent moon. For a 2D shape, you could use a polygon, thin prism,
difference of cylinders, etc...just make half a circle, and cut out an
ellipse with a major radius equal to the circle radius.
> <0,-MajorRadius>.
Sounds like you might be talking about a cycloid:
http://mathworld.wolfram.com/Cycloid.html
You want one "hump" of a cycloid with the ends at each point of a
half-circle, and the peak at the peak of a smaller circle centered in
the larger one? That doesn't really match what you describe, but it's
the only way I can think of to get a crescent shape from a cycloid and
circles.
http://tag.povray.org/
Date: 31 Jan 2004 04:44:19
Message: <opr2mwbppampsiks@news.povray.org>
On Fri, 30 Jan 2004 15:19:01 -0500, Christopher James Huff
>> up
>> <0,-MajorRadius>.
> circles.
I was messing with a logoey-type background and originally did it in a 2D
paint package but it looked way too flat even with lighting effects so I
thought I'd knock one up in POV; shouldn't take long :)
I was trying to sort-of make one of those crescent-moon pendants.Flat-base
with a straight 45 degree slope up and then a flat internal 45 degree
slope down, the end points of the crescent ending at the base level, hence
the use of cones over spheres*. The problem was if I just use an upside
down cone for the internal curve; although from a straight on perspective
and shadowless it looks fine, different angles and shadows reveal it's not
joined at the 'points' of the crescent. Which means tilting the internal
cone to join the points; which means the slope is no longer 45 degrees;
which means recalculating the radii of the cones, which is where it got
fun.
I've pretty much got it working now, although the internal crescent
doesn't *quite* join the external one at all points it's close enough not
to be barely noticable.
Thanks for taking the time to try to help, I'm sure there's probably a
much easier way to do this; as if there's a hard way and a easy way: I'm
bound to take the hard way first :)
Phil
*I would still end up needing to calculate the center of a sphere using
four points in order to get the right sizes and angles which sounds like
even more fun :).
