POV-Ray : Newsgroups : povray.newusers : isosurfaces? Server Time
19 Mar 2026 05:47:27 EDT (-0400)
  isosurfaces? (Message 11 to 13 of 13)
Subject: Re: isosurfaces?
Date: 4 Nov 2003 07:58:15
Message: <3fa7a267$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3fa7a09a@news.povray.org...
> Christoph Hormann <chr### [at] gmxde> wrote:
> > Actually you should use sqrt() instead of pow(,0.5).
>   How about simply squaring the radius (R*R) instead of using the slow
> sqrt() function?-)
He's got a point.... in which case it would make sense to declare R as the
square of whatever value you want to use?
So, Chris's example becomes:
#declare R=2*2;
#declare FSphere=function {(x*x+y*y+z*z) - R}
Date: 4 Nov 2003 08:30:17
Message: <3fa7a9e9@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
> #declare R=2*2;
  Having the radius as parameter has certain advantages, though.
For instance, the radius does not have to be constant thorough the
entire surface of the sphere... :)
  Example:
#declare FSphere = function(x,y,z,R) { (x*x+y*y+z*z) - R*R }
isosurface
{ function { FSphere(x,y,z, 2-.5*f_noise3d(x*5,y*5,z*5)) }
Date: 4 Nov 2003 12:32:03
Message: <p94l71-s2l.ln1@triton.imagico.de>
> sqrt() function?-)
Because that function would have a non-constant gradient.  With the (way
too large) container box{-5,5} you need quite a high max_gradient to
correctly render it -> it will be slower than with sqrt().
Of course using the internal function f_sphere() would be even faster.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
