POV-Ray : Newsgroups : povray.newusers : new guy here needs help Server Time
21 Nov 2025 05:21:40 EST (-0500)
  new guy here needs help (Message 1 to 4 of 4)
Subject: new guy here needs help
Date: 19 Aug 2003 12:09:40
Message: <matt-pace-AD18FA.09093819082003@netplex.aussie.org>
hi there, my names matt.  ive been using pov for a couple of months off
and on now.  i have a few questions.  first of all, i need a good place
to learn about media, specifically, media inside of objects.  next, i
have a math/coding question.  i am attempting to have a bunch of
cylinders have one base one the imaginary surface of a 3 unit wide
sphere and the other side on the inside surface of an imaginary sphere
with a 5 unit diameter.  this is what i have so far:
camera
   location <0,-11,-7>
   look_at <0,-2,0>
light_source
   <5,5,5>
   color rgb <2,2,2>
#declare circ_large_diam=5;
#declare circ_small_diam=3;
#declare y_coord_outer=2.5;
#declare y_coord_inner=1.5;
#declare point_step=10;
#declare current_point=0;
#declare ending_point=360;
#while (y_coord_outer=2.5 >= -2.5)
   #while (current_point <= ending_point)
      cylinder
<cos(radians(current_point))*circ_large_diam,y_coord_outer,sin(radians(cu
rrent_point))*circ_large_diam>,<cos(radians(current_point))*circ_small_di
am,y_coord_inner,sin(radians(current_point))*circ_small_diam>, .15
         texture
            pigment
               color rgbf <.2,.2,.6,.5>
      #declare current_point=current_point+point_step;
   #declare circ_small_diam=circ_small_diam-.3;
   #declare circ_large_diam=circ_large_diam-.5;
   #declare currnet_point=0;
   #declare y_coord_outer=y_coord_outer-.25;
   #declare y_coord_inner=y_coord_inner-.15;
global_settings
assumed_gamma 1.0
ambient_light color rgb <1,1,1>
before, i had terribly variable names, it would have been tough for you
to decipher them.  the problem then was there there was a degenerate
cylinder (base pt= apex pt), and the error appeared at line 24 or
something (where the texture beginning is), so the error was most likely
where teh points of the cylinder are declared (big duh).  now, after i
changed the names, it wont even parse anymore, it starts teh parser, and
doesnt parse any lines.  i think i may have to change the double closing
parenthesis to after teh multiplication of the diameter, but im not
sure.  any help would be great
thanks a lot
~matt
Subject: Re: new guy here needs help
Date: 19 Aug 2003 15:02:51
Message: <3f42745b$1@news.povray.org>
Hi Matt,
I've tried to render your scene and have found some errors (and have some
comments that don't refer to an error):
- In the line containing
  the "=2.5" is nonsense (copy-and-paste error?).
- In the line (near the end) containing
  the name of the variable should be current_point.
- In this line:
  the "<=" should be replaced by "<" because current_point starts at 0
  which is the same (angle) as 360.
- Your formula for the endpoints of the cylinder doesn't put them onto
  the inner and outer sphere; instead of circ_large_diam in these
  formulas use
  sqrt(circ_large_diam*circ_large_diam-y_coord_outer*y_coord_outer)
  and instead of circ_small_diam use
  sqrt(circ_small_diam*circ_small_diam-y_coord_inner*y_coord_inner)
  (and don't change circ_large_diam and circ_small_diam!)
- Using variable names without uppercase letters is a bit risky because
  such names might collide with (current or future) keywords. (The POV-
  team has promised never to use uppercase letters in keywords.)
- In the cylinder formulas, the variable circ_large_diam is used like a
  radius, not a diameter. If it's meant as diameter, then all the
  cylinders with y_coord_outer=2.5 will be identical (same with -2.5).
- The ???_point variables were self-explanatory if renamed to ???_angle.
- cumulating non-integer values in #while loops might give a wrong
  result due to rounding errors -- it's better to use an integer counter
  like this:
  #declare Number=36;
  #declare Counter=0;
  #while (Counter<Number)
    #declare Angle=360*Counter/Number;
    // use this Angle here
    #declare Counter=Counter+1;
    #end//while Counter
What about the following scene? (Simply copy this *whole* post to POV-
Ray and render!)
   Sputnik
camera { location <0, 5, -10> look_at 0 }
light_source { <-5,5,-5> color rgb <2,2,2> }
#declare OuterRadius=5;
#declare InnerRadius=3;
#declare MaxHeight=2.5;
#declare CylRadius=0.10;
#declare NumberOfHeights=21;
#declare NumberOfAngles=36;
#declare Fraction=InnerRadius/OuterRadius;
#declare HeightCount=0;
#while (HeightCount<NumberOfHeights)
  // HeightCount=0...NumberOfHeights-1 -> Height=MaxHeight...-MaxHeight
  #declare Height=MaxHeight-2*MaxHeight*HeightCount/(NumberOfHeights-1);
  #declare AngleCount=0;
  #while (AngleCount<NumberOfAngles)
    #declare Radius=sqrt(OuterRadius*OuterRadius-Height*Height);
    #declare OuterPoint=<Radius, Height, 0>; // Angle ignored for the moment
    cylinder { OuterPoint, OuterPoint*Fraction, CylRadius
        pigment { color rgbf <.2,.2,.6,.5> }
        finish { ambient .4 diffuse .6 }
      rotate AngleCount/NumberOfAngles*360*y // let POV do the trigonometry!
      }//cylinder
    #declare AngleCount=AngleCount+1;
    #end//while AngleCount
  #declare HeightCount=HeightCount+1;
  #end//while HeightCount
Date: 19 Aug 2003 15:03:34
Message: <3f427486@news.povray.org>
"Matthew Pace" <mat### [at] lycoscom> wrote in message
news:mat### [at] netplexaussieorg...
<snip>
Okay, you introduced the following error when you changed the variable
names:
but this line is weird too (imho):
#while (y_coord_outer >= -2.5) // what?
Correct them, and I get your degenerate point error.
Now, given your condition:
and:
and:
and that you will get an error if the two values are equal, it follows that
they reach equality prior to or at the condition.
You can fix it by modifying the condition to:
#while (y_coord_outer >= -2.5 & y_coord_outer != y_coord_inner)
but I've no idea if this is your intent.
Date: 19 Aug 2003 23:50:21
Message: <matt-pace-3FA4CA.20502019082003@netplex.aussie.org>
Thanks a lot, both you guys.  Its people like you that make the world a
better place, looking out for the n00bs and such.
mad props.
matt
