kurtz le pirate <kur### [at] yahoo fr> wrote:
> Hello,
> I made a simple isosurface defined as a cylinder minus a groove :
> function { sqrt(pow(x,2) + pow(z,2)) - Groove(x,z) }
> with :
> Groove = function(a,b) { R + q - 2*q*abs(cos(ang(a,b)))}
> Now, a want to twist this isosurface along y axis. I found on Internet
> that, x and z must be modified with functions like this :
> TwistX = function { x*cos(a*y) - z*sin(a*y) }
> TwistZ = function { x*sin(a*y) + z*cos(a*y) }
> ok... but how to 'put' this twist's functions 'in' my main isosurface
> function ?
> this should be simple, but I can not do :(
> thanks.
> klp
A working scene would be easier.
This is a scene I keep to help me with twisting.
// perspective (default) camera
location <0.0, 2.0, -5.0>
look_at <0.0, 0.0, 0.0>
// create a regular point light source
light_source {
0*x // light's position (translated below)
color rgb <1,1,1> // light's color
translate <-20, 40, -20>
// sets the default texture that objects get when they have no texture specified
#default {
texture { pigment {color red 1} finish{ambient 0.2} }
// Set a color of the background (sky)
background { color rgb< 1, 1, 1> }
// internal functions usable in user defined functions
// for example for isosurfaces and function pattern
#include "functions.inc"
box{<-1,-.5,-.5>,<1,.5,.5>
//rotate<0,90,0> //for end view
isosurface{
function { max((x*x-2),(y*y-.25),(z*z-.25)) }
contained_by { box{<-1,-1,-1>,<1,1,1>} }
max_gradient 1.8
translate<0,1.5,0>
#declare N_turns=.125; // per pov unit
isosurface{
//function { max((x*x-2),(y*y-.25),(z*z-.25)) }
// replace y with
z*sin(x*2*pi*N) + y*cos(x*2*pi*N)
// replace z with
z*cos(x*2*pi*N) - y*sin(x*2*pi*N)
function { max((x*x-2.),((z*sin(x*2*pi*N_turns) +
y*cos(x*2*pi*N_turns))*(z*sin(x*2*pi*N_turns) +
y*cos(x*2*pi*N_turns))-.25),((z*cos(x*2*pi*N_turns) -
y*sin(x*2*pi*N_turns))*(z*cos(x*2*pi*N_turns) - y*sin(x*2*pi*N_turns))-.25)) }
max_gradient 2.91
translate<0,-1.5,0>
#declare N_turns=-.125; // per pov unit, turn other direction
isosurface{
// replace y with
// replace z with
max_gradient 2.91
translate<2.5,-1.5,0>
#declare N_turns=.125; // per pov unit, also turn other direction
isosurface{
// replace y with
z*sin(x*2*pi*N) - y*cos(x*2*pi*N)
// replace z with
z*cos(x*2*pi*N) + y*sin(x*2*pi*N)
function { max((x*x-2.),((z*sin(x*2*pi*N_turns) -
y*cos(x*2*pi*N_turns))*(z*sin(x*2*pi*N_turns) -
y*cos(x*2*pi*N_turns))-.25),((z*cos(x*2*pi*N_turns) +
y*sin(x*2*pi*N_turns))*(z*cos(x*2*pi*N_turns) + y*sin(x*2*pi*N_turns))-.25)) }
max_gradient 2.91
translate<-2.5,-1.5,0>
**** be carefull of word wrap.
for you, it might be....
//function { sqrt(pow(x,2) + pow(z,2)) - Groove(x,z) }
function { sqrt(
pow(x,2)
+ pow(z,2)
)) - Groove(x,z)
function { sqrt(
pow(x*cos(a*y) - z*sin(a*y),2)
+ pow(x*sin(a*y) + z*cos(a*y),2)
)) - Groove(x*cos(a*y) - z*sin(a*y),x*sin(a*y) + z*cos(a*y))
Hope this helps:-)
Stephen S
> Hello,
> with :
> function ?
> thanks.
One possibility would be to add that twist in the function call:
#declare Grooved_Cylinder = function { sqrt(pow(x,2) + pow(z,2)) -
Groove(x,z) }
object{Grooved_cylinder(x*cos(a*y) - z*sin(a*y), y, x*sin(a*y) + z*cos(a*y))
This will displace the sample points passed to the function and make it
look twisted.
To reverse the twisting direction, use -y in the sin and cos.
