POV-Ray : Newsgroups : povray.newusers : read colors from file Server Time
29 Sep 2024 04:19:50 EDT (-0400)
  read colors from file (Message 1 to 2 of 2)
Subject: read colors from file
Date: 10 Jun 2007 02:12:06
Message: <kurtzlepirate-6907DD.08120610062007@news.povray.org>
hello.
i am trying to read colors (as defined in colors.inc) from a file. code
part here :
#declare fileName = "datas.txt";
#declare infos = array[20][3];
#set index=0;
#fopen FILE fileName read
#while (defined(FILE))
  #read (FILE,pourcentage,decalage,couleur)
  #declare infos[index][0] = pourcentage;
  #declare infos[index][1] = decalage;
  #declare infos[index][2] = couleur;
  #set index=index+1;
#fclose FILE
if "datas.txt" contains :
2, 0, Red
12, 1, Green
i get a parse error : expected 'float, vetor or string literal', colour
identifier found instead for the first line of the file.
2, 0, "Red"
12, 1, "Green"
i get a parse error for the line "#declare infos[index][2] = couleur" :
attempted to redefine float identifier as string identifier.
any chance to read a "named color" from a file an put it in an array ?
klp
Subject: Re: read colors from file
Date: 10 Jun 2007 03:01:53
Message: <466ba1e1$1@news.povray.org>
You can only read CSV floats, vectors, and
quote delimited strings from a file.
Arrays can only hold elements of the same type.
You can use three arrays instead though.
Then you can construct a string to parse with
the Parse_String macro in strings.inc, and that
will convert a string like "Red" to a color identifier.
#include "strings.inc"
#declare pourcentage = array[20];
#declare decalage = array[20];
#declare infocouleur= array[20];
#set index=0;
  #read (FILE,P,D,C)
  #declare pourcentage[index]= P;
  #declare decalage[index]=D;
  cmd=concat("#declare infocouleur[index]=",C,";")
  Parse_String(cmd)
  #set index=index+1;
#fclose FILE
Date: 10 Jun 2007 10:40:46
Message: <kurtzlepirate-38CC25.16404510062007@news.povray.org>
In article <466ba1e1$1@news.povray.org>,
> #set index=0;
>   #read (FILE,P,D,C)
>   Parse_String(cmd)
>   #set index=index+1;
> #end
> #fclose FILE
thank tim. very very interresting things in your post : writing in a
file then including it !!
just correcting with #declare cmd=...
klp
