POV-Ray : Newsgroups : povray.newusers : object name problem Server Time
26 Mar 2026 04:35:51 EDT (-0400)
  object name problem (Message 1 to 4 of 4)
Subject: object name problem
Date: 9 May 2013 09:00:20
Message: <kurtzlepirate-3A0A2B.15002009052013@news.povray.org>
hello,
I have a macro that generates a mesh object in a "inc" file.
I declare a variables :
  #declare objectName = "TheBrick";
My macro write this name in the inc file with this code :
   #write(OUTFILE,"#declare ",objectName," = mesh {\n")
which generates :
#declare TheBrick = mesh {
  triangle {<-4.25,2.25,-3.25>,<-3.57,2.33,-3.33>,<-4.33,2.33,-2.57>}
  triangle {<-4.33,2.33,-2.57>,<-3.57,2.33,-3.33>,<-3.57,2.52,-2.57>}
  triangle {<-3.57,2.33,-3.33>,<-3.15,2.33,-3.33>,<-3.57,2.52,-2.57>}
Now, in the main script if i write :
#include fileName
object {
  objectName
  pigment { color White }
  finish { ambient 0 }
I get this parse error :
  Expected 'object', string identifier found instead.
Seems consistent, but then how can I use this variable to draw object ?
Of corse, if i write :
object {
  TheBrick
everything is good.
klp
Subject: Re: object name problem
Date: 9 May 2013 11:10:00
Message: <web.518bbc059f3aa2d281c811d20@news.povray.org>
kurtz le pirate <kur### [at] yahoofr> wrote:
> hello,
> which generates :
> #include fileName
> object {
>   objectName
> object {
>   TheBrick
> everything is good.
> klp
You are trying to use 'objectname' as an indirect reference which can't work in
POV.  At runtime, it does not substitute "TheBrick" text in place of the
"objectname" text, instead it simply sees 'ojectname' as a string and not an
object, hence the error.
-tgq
Date: 9 May 2013 20:12:16
Message: <518c3b60$1@news.povray.org>
Am 09.05.2013 15:00, schrieb kurtz le pirate:
> which generates :
> #include fileName
> object {
>    objectName
Try the "Parse_Strings" macro:
   #include "strings.inc"
   object {
     Parse_String(objectName)
Date: 11 May 2013 03:36:59
Message: <kurtzlepirate-08FB05.09365811052013@news.povray.org>
In article <518c3b60$1@news.povray.org>,
>    object {
i try... thanks
klp
