POV-Ray : Newsgroups : povray.newusers : need some help ! Server Time
26 Mar 2026 11:23:39 EDT (-0400)
  need some help ! (Message 1 to 5 of 5)
Subject: need some help !
Date: 14 Nov 2010 06:05:23
Message: <kurtzlepirate-2E05A9.12053314112010@news.povray.org>
hi,
i get this error but i am unable to understand why.
everything seems good...
File Context (5 lines):
  #local a = 1/sqrt(2.0);
  #local i = 0;
  #while(i<6)
    p[i].x =
Parse Error: All #declares of float, vector, and color require
semi-colon ';' at end if the language version is set to
 3.5 or higher. Either add the semi-colon or set the language version to
3.1 or lower.
source code :
#macro CreateNSphere (iterationNumber)
  #local p = array[6];
  #local p[0] = < 0, 0, 1>;
  #local p[1] = < 0, 0,-1>;
  #local p[2] = <-1,-1, 0>;
  #local p[3] = < 1,-1, 0>;
  #local p[4] = < 1, 1, 0>;
  #local p[5] = <-1, 1, 0>;
  // --- Create the level 0 object
  #local i = 0;
  #while(i<6)
    p[i].x = a*p[i].x;
    p[i].y = a*p[i].y;
    #local i=i+1;
  #declare facettes[0] = triangle { p[0], p[3], p[4] };
and this macro is called with this line :
  #declare fCreated = CreateNSphere(0);
nothing too complicated :(((
thanks
klp
Subject: Re: need some help !
Date: 14 Nov 2010 07:46:30
Message: <4cdfda26$1@news.povray.org>
On 11/14/2010 07:05 AM, kurtz le pirate wrote:
>     p[i].x = a*p[i].x;
>     p[i].y = a*p[i].y;
forgot something?
Date: 14 Nov 2010 08:15:00
Message: <web.4cdfe0bb48b0137b3cc273c80@news.povray.org>
> >     p[i].x = a*p[i].x;
> >     p[i].y = a*p[i].y;
> forgot something?
#declare or #local I think...
Stephen S
Date: 14 Nov 2010 15:00:58
Message: <4ce03ffa$1@news.povray.org>
>>>      p[i].x = a*p[i].x;
>>>      p[i].y = a*p[i].y;
>> forgot something?
> Stephen S
#local if you only use the array inside that macro.
#declare if you need your array outside the macro, of the array is first
declared outside the macro.
Date: 15 Nov 2010 05:02:31
Message: <kurtzlepirate-09F7E1.11022915112010@news.povray.org>
In article <web.4cdfe0bb48b0137b3cc273c80@news.povray.org>,
> > >     p[i].x = a*p[i].x;
> > >     p[i].y = a*p[i].y;
> > forgot something?
yes, you're right. it's too obvious :((
thanks
klp
