POV-Ray : Newsgroups : povray.newusers : how assumed_gamma works Server Time
7 Jan 2026 00:47:26 EST (-0500)
  how assumed_gamma works (Message 11 to 14 of 14)
Subject: Re: how assumed_gamma works
Date: 19 Nov 2001 06:37:29
Message: <ebrhvtked9sr7hs098f06dnq3fun6mlqe3@4ax.com>
On Mon, 19 Nov 2001 13:27:24 +0200, Kari Kivisalo <ray### [at] engineercom> wrote:
> This is how gamma in povray works.
Thanks, if it is all true it is best ascetic tutorial about it :-)
Why it can't be described within documentation this short way ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 19 Nov 2001 06:46:31
Message: <3bf8f117@news.povray.org>
Try using another image format (eg. tga) and see if the problem still happens
there. If it doesn't happen, then the problem is simply the wrong PNG gamma
correction value. If it does, then the problem is somewhere else.
Date: 19 Nov 2001 07:02:45
Message: <Xns915E84B52D17seed7@povray.org>
It will be.
Ingo
Date: 19 Nov 2001 07:57:48
Message: <7c0ivtggtgm49457c94bsru870gd2mg0da@4ax.com>
>Recommended value for assumed_gamma is 1.
But there is another question: what is the fastest way of adjusting designed
enviroment_map to be rerendered with assumed_gamma 1? Adjusting could be started
from calculated factor for color values? How calculate this ?
ABX
