POV-Ray : Newsgroups : povray.newusers : Layered transparency Server Time
22 Dec 2025 14:10:57 EST (-0500)
  Layered transparency (Message 1 to 3 of 3)
Subject: Layered transparency
Date: 19 Jan 2004 14:28:58
Message: <fontd1-bqa.ln1@worldmusic.grep.be>
I'm trying to create a wall with a graffiti image on it. To that
end, I downloaded a grafitti image from a website, converted it to a
.png, made some part of it transparent, and layered it over a brick
caused the brick pattern to become transparent as well.
Thus, I converted the .png to a .gif, and would want to use the
transmit bitmap modifier to get the desired effect, but I can't seem
to guess the right color number, and I'm reluctant to try all 256
possibilities; I'm not even sure whether what I'm doing is the right
way.
Could any kind soul tell me what the best way to layer a
partially-transparent image map over a patterned pigment is? And if
I'm doing the best possible thing with those "transmit" modifiers, how
I can efficiently determine the right color index to make it work?
TIA,
Wouter Verhelst
Debian GNU/Linux -- http://www.debian.org
Nederlandstalige Linux-documentatie -- http://nl.linux.org
"Stop breathing down my neck." "My breathing is merely a simulation."
"So is my neck, stop it anyway!"
  -- Voyager's EMH versus the Prometheus' EMH, stardate 51462.
Subject: Re: Layered transparency
Date: 19 Jan 2004 15:14:30
Message: <400c3aa6@news.povray.org>
  That's not because there would be something wrong with using a png.
It's because you defined your texture wrong.
  You should post a small (but complete, ie. renderable) piece of code
demonstrating what you are doing.
Date: 19 Jan 2004 20:00:15
Message: <m78ud1-1a2.ln1@worldmusic.grep.be>
In article <400c3aa6@news.povray.org>,
	Warp <war### [at] tagpovrayorg> writes:
Ah.
Heh. Well, trying to reconstruct what I did with the .png file before
(I had since switched to a different setup using a .gif) didn't work.
Instead, I accidentally seem to have done the right thing; it now
nicely gives me the graffiti image on a background of a brick pattern,
which is what it should be doing.
I don't even remember how it was when it didn't work; but as it now
does what I want it to do, I'd say we can consider this issue
fixed. Thanks!
Wouter Verhelst
