POV-Ray : Newsgroups : povray.newusers : Re: 35.43inx59.0.5in image size Server Time
22 Jul 2025 16:35:05 EDT (-0400)
  Re: 35.43inx59.0.5in image size (Message 1 to 9 of 9)
Subject: Re: 35.43inx59.0.5in image size
Date: 16 Aug 2005 07:40:01
Message: <ddsj44$5po$1@chho.imagico.de>
Oleguer Vilella wrote:
> Hi all,
> I've to render a very big image. What format output file will be the best?
> I can't render it using .BMP.
Of course BMP is a very bad choice as output format for POV-Ray but it
is unlikely that you run into any format specific limit.  The size limit
of BMP is probably even higher than 65535x65535.  You will however run
into trouble if your OS does not support very large files (the above
size with 24bpp, uncompressed is already 12 GB)
Using PNG of PPM should be fine for all image sizes you might seriously
want to render (but as said subject to the OS/file system capabilities).
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 16 Aug 2005 07:44:20
Message: <4301d194@news.povray.org>
Hi Christoph,
Yeah, I think PNG will be the best. But using Windows I've to render it
with -D to close the preview window, because if I use the preview window it
gives an error.
And Targa format?
Oleguer
news:ddsj44$5po$1@chho.imagico.de...
>> Hi all,
>> best?
> Of course BMP is a very bad choice as output format for POV-Ray but it is
> unlikely that you run into any format specific limit.  The size limit of
> BMP is probably even higher than 65535x65535.  You will however run into
> trouble if your OS does not support very large files (the above size with
> Christoph
Date: 16 Aug 2005 07:59:30
Message: <4301d522@news.povray.org>
Oleguer Vilella <ole### [at] infonegociocom> wrote:
> And Targa format?
  What is it that you require from the image format? I didn't get that.
Date: 16 Aug 2005 09:00:20
Message: <4301e364@news.povray.org>
Yeah, file size and quality.
news:4301d522@news.povray.org...
>> And Targa format?
>                                                          - Warp
Date: 17 Aug 2005 04:04:27
Message: <4302ef8b@news.povray.org>
  Well, for quality there's absolutely no difference between image
formats because all of them (ie. the ones supported by povray as output)
are lossless full-color formats.
  As for size, there's only one option: PNG.
Date: 17 Aug 2005 06:10:20
Message: <43030d0c@news.povray.org>
Hi Warp,
All right. So I've done it right. I've done the image on Linux using PNG.
Thanks,
Oleguer
news:4302ef8b@news.povray.org...
>                                                          - Warp
Date: 19 Aug 2005 07:16:27
Message: <4305bf8b@news.povray.org>
Note that POV-Ray doesn't compress PNG images as well as it could. If you
really want the compression (for instance, if you plan on posting it on the
newsgroups), you'll have to bring it into a 2D image editor and resave it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Aug 2005 08:21:59
Message: <4305cee6@news.povray.org>
  The file sizes don't differ all that much from optimized pngs...
> If you
  Better to use a png optimizer (such as optipng or advpng) than just a
random image editor (which usually do a rather poor job).
Date: 19 Aug 2005 09:04:15
Message: <4305d8cf@news.povray.org>
Well, sometimes I used PhotoShop to resize images and to change the file
format.
Oleguer
news:4305cee6@news.povray.org...
>> If you
>> the
>> it.
>                                                          - Warp
