I'm trying to do the bobby hat -thing and my functions give extraneous
sharp edges. The following script has commented out the kind of thing I'm
looking for (made with a pattern) and the problematic line uncommented.
global_settings {assumed_gamma 2.4 }
plane {
y, -1.8
pigment { checker DarkTan DarkOliveGreen }
light_source { <5, 14, -8> color White }
location <0, 0, -4>
look_at 0 angle 46
rotate x*7 rotate y*6 }
#declare ndist = function (x,y) {
sqrt(pow(x,2)+pow(y,2))/sqrt(2)
height_field {
function 100, 100 {
// pattern { waves scale .1 }
1+cos(2*pi*ndist(x,y))
pigment { DarkOrchid }
translate -.5
scale <2, .5, 2>
I'm not sure I understand what that's supposed to do, but I'll have a go at
fixing it. I think the ranges of your numbers are wrong, is this more the
effect you were after?
height_field {
function 100, 100 {
.5+.5*cos(2*pi*ndist(x*2-1,y*2-1))
translate -.5
scale <2, .5, 2>
What I've done is change x & y to (x*2-1,y*2-1), so they go from -1 to 1
(heightfields use 0 to 1) and change the output so it's between 0 and 1
(.5+.5*cos), your original function was outputting values between 0 and 2
(1+cos) so when it went above 1 it wrapped round to zero again, hence a
sharp change.
Hope that helps :)
Tek
http://evilsuperbrain.com
"Kari Ojala" <kar### [at] iki fi> wrote in message
news:Xns9878BC4562324kariojalaikifi@203.29.75.35...
> plane {
> y, -1.8
> camera {
> location <0, 0, -4>
> look_at 0 angle 46
> height_field {
> function 100, 100 {
> translate -.5
> scale <2, .5, 2>
"Tek" <tek### [at] evilsuperbrain com> wrote in news:45588b34$1@news.povray.org:
> 1 (heightfields use 0 to 1) and change the output so it's between 0
> and 1 (.5+.5*cos), your original function was outputting values
> between 0 and 2 (1+cos) so when it went above 1 it wrapped round to
> zero again, hence a sharp change.
> Hope that helps :)
Absolutely. It looked even better than I remembered it would. The thing I
remember is that this is not the first time I've had problems with ranges.
Just like in a supermarket: I go looking for juice and come out drinking
pure concentrate.
Cheers,
Kari O.
