POV-Ray : Newsgroups : povray.newusers : camera setup for a skybox Server Time
29 Sep 2024 14:07:41 EDT (-0400)
  camera setup for a skybox (Message 1 to 7 of 7)
Subject: camera setup for a skybox
Date: 28 Feb 2006 07:02:28
Message: <Xns977884A9531C3emzicNOSPAMembegecom@203.29.75.35>
hello,
i want to generate 6 quadratic images to be used as skybox textures in a
game. but unfortunately i have no idea how to set up the camera correctly
besides that it has to look into the 6 different directions.
i would be very grateful for any help on this.
thank you!
Subject: Re: camera setup for a skybox
Date: 28 Feb 2006 07:55:01
Message: <web.44044723a7dd28121c6902970@news.povray.org>
emzic <emz### [at] SPAMembegecom> wrote:
> hello,
> thank you!
maybe this can help:
http://news.povray.org/povray.macintosh/thread/%3Cr### [at] netplexaussieorg%3E/?ttop=214395&to
ff=100
H
Date: 28 Feb 2006 08:05:00
Message: <web.44044a50a7dd28121c6902970@news.povray.org>
> > hello,
> > thank you!
sorry, the url was too long; try this:
http://tinyurl.com/pctrj
H
Date: 28 Feb 2006 08:21:25
Message: <Xns9778920C76B0BemzicNOSPAMembegecom@203.29.75.35>
"helge_h" <nomail@nomail> wrote in
news:web.44044a50a7dd28121c6902970@news.povray.org:
>> > hello,
>> > in a game. but unfortunately i have no idea how to set up the
>> > camera correctly besides that it has to look into the 6 different
>> > directions.
>> > thank you!
thank you!
unfortunately those six images dont fit together at all. i was even
trying to stitch them together in photoshop but couldnt find any matching
edges.
meanwhile i could create matching front, back, left and right textures
using an angle of 90.
	location <0, 0, 0>
	look_at <1, 0, 0> //vary the direction here
    	angle 90
just the top and bottom textures dont seem to match when i use look_at
<0,-1,0> and <0,1,0>
thank you for any help!
Date: 28 Feb 2006 08:49:40
Message: <Xns977896D613214emzicNOSPAMembegecom@203.29.75.35>
ok, i could just solve it using paul bourkes approach:
http://astronomy.swin.edu.au/~pbourke/projection/cuberender/#povray
Date: 28 Feb 2006 09:00:19
Message: <44045773@news.povray.org>
"emzic" <emz### [at] SPAMembegecom> wrote in message
news:Xns9778920C76B0BemzicNOSPAMembegecom@203.29.75.35...
> ... snip ...
> camera {
> location <0, 0, 0>
>    angle 90
I think you're nearly there, it's probably just that the default aspect
ratio is 4 to 3, so if you add a right vector and an up vector with length 1
then you should be able to generate 6 squares that fit together around a
cube. The example below illustrates this.
Note. The image width and height you generate will need to be equal,
otherwise it still won't help much.
Chris B.
camera {location <0,0,0>
  look_at <0,-1,0>
  angle 90
  right x
  up y
light_source{0 rgb 1}
cylinder {<-1,-1, 1><-1, 1, 1>,0.08 pigment {color rgb <1,0,0>}}
cylinder {< 1,-1, 1>< 1, 1, 1>,0.08 pigment {color rgb <1,1,0>}}
cylinder {<-1,-1,-1><-1, 1,-1>,0.08 pigment {color rgb <1,0,1>}}
cylinder {< 1,-1,-1>< 1, 1,-1>,0.08 pigment {color rgb <0,1,1>}}
Date: 4 Mar 2006 03:27:24
Message: <44094f6c$1@news.povray.org>
I usually use this:
 location 0
 right x
 up y
 direction z
 angle 90
 #if (frame_number = 0)
  look_at  x
 #else #if (frame_number = 1)
  look_at  -x
 #else #if (frame_number = 2)
  look_at  y
 #else #if (frame_number = 3)
  look_at  -y
 #else #if (frame_number = 4)
  look_at  z
 #else #if (frame_number = 5)
  look_at  -z
 #end #end #end #end #end #end
With command line options +kfi0 +kff5
- Slime
 [ http://www.slimeland.com/ ]
