POV-Ray : Newsgroups : povray.newusers : Linux install Server Time
21 Mar 2026 10:53:37 EDT (-0400)
  Linux install (Message 1 to 7 of 7)
Subject: Linux install
Date: 13 Dec 2003 22:08:40
Message: <Xns94512A1271125raf256com@204.213.191.226>
I'm a newbie to linux, i'm trying to install pov on my collage linux
account, but there is problem (probably because I dont have root
permision).
Do I realy must have root permisions, since I just want to run povray, or
to install it ONLY for my user (i.e. not for every user of the machine)
Subject: Re: Linux install
Date: 13 Dec 2003 22:15:02
Message: <Xns94512B26B43C1raf256com@204.213.191.226>
spa### [at] raf256com news:Xns### [at] 204213191226
> permision).
More exacly:
drwxrwxrwx   15 rmaj     student      2048 Oct 22  2002 scenes
drwxrwxrwx    2 rmaj     student      2048 Oct 22  2002 scripts
drwxrwxrwx    2 rmaj     student      2048 Oct 22  2002 tests
bash-2.05a$ ./install
cp: cannot create directory `/usr/local/share/povray-3.5': Permission
denied
mv: cannot stat `/usr/local/share/povray-3.5/povray.1': No such file or
directory
mv: cannot stat `/usr/local/share/povray-3.5/povray': No such file or
directory
mv: cannot stat `/usr/local/share/povray-3.5/povray.ini': No such file or
directory
mv: cannot stat `/usr/local/share/povray-3.5/povray.conf': No such file or
directory
mkdir: cannot create directory `/usr/local/share/doc': Permission denied
mv: cannot stat `/usr/local/share/povray-3.5/povray-3.5*': No such file or
directory
Date: 13 Dec 2003 22:56:36
Message: <3fdbdf74@news.povray.org>
Simply copy the povray binary which was built to somewhere and the
povray.conf to ~/.povray.conf (and povray.ini to ~/.povrayrc if you
want) and that's it.
Date: 13 Dec 2003 22:59:03
Message: <3fdbe007@news.povray.org>
(Of course you might also want to copy the contents of the include
directory somewhere and put a proper +L line on ~/.povrayrc as well...)
Date: 14 Dec 2003 11:37:44
Message: <Xns9451B339C22C9raf256com@204.213.191.226>
war### [at] tagpovrayorg news:3fdbdf74@news.povray.org
Oh yes, I didnt noticed that binary was already build :)
Date: 14 Dec 2003 14:18:59
Message: <Xns9451CE8F0F1ADraf256com@204.213.191.226>
But, I still have problem, PovRay starts but he complains about acces
denied to povray.ini and suggesting me to modify povray.conf
can povray.conf be placed in same directory where pov executable is?
Povray.conf and povray.ini has mode 777, and in povray.conf security is
disabled (as default - so its relaing on filemode settings).
What to change to make it work?
Date: 14 Dec 2003 16:16:13
Message: <3fdcd31d@news.povray.org>
  Did you read my reply?
  Copy povray.conf to ~/.povray.conf
  Extremely bad idea.
