POV-Ray : Newsgroups : povray.newusers : .rca Server Time
21 Nov 2025 14:52:04 EST (-0500)
  .rca (Message 1 to 5 of 5)
Subject: .rca
Date: 4 Oct 2002 08:07:29
Message: <Xns929D8F490142raf256com@204.213.191.226>
Hellow,
how can I stop POV from creating temporary files *.rca (for radiosity save)
or to create them in another directory/file (best - c:\images\temp.rca) ?
When I abort render with radiosity - this sometimes huge file stays on
disc.
Subject: Re: .rca
Date: 4 Oct 2002 08:19:21
Message: <3d9d8748@news.povray.org>
Rafal 'Raf256' Maj <raf### [at] raf256com> wrote:
> Hellow,
  By not using radiosity?-)
> disc.
  The file is kept in case you want to continue the render afterwards.
  (Of course if this file is created when no image file is created, then
it's useless. I haven't tried if this happens, but if it does, then it
might be a good idea to change this.)
Subject: Re: .rca
Date: 4 Oct 2002 08:29:53
Message: <Xns929D93352B0EBraf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d9d8748@news.povray.org
>> on disc.
how about give an option to switch it off ? My c:/dev/pov/ has 90 MB due to
.rca's :)
Subject: Re: .rca
Date: 4 Oct 2002 08:43:39
Message: <Xns929D9594D4F3APhiLho@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226:
>>> on disc.
> to .rca's :)
As a workaround, you can make a script (batch or other) to clean up this
directory. Of course, you still have to run the batch. Or to add a shell
command at the beginning of the POV scene...
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Subject: Re: .rca
Date: 4 Oct 2002 09:49:53
Message: <Xns929DA1D534434seed7@povray.org>
>> due to .rca's :)
> this directory. Of course, you still have to run the batch.
5.2.4.3  Shell Command Return Actions
 User_Abort_Return=s Set user abort return actions
Ingo
