Warp <war### [at] tag povray org> wrote in news:3d9b0a4f@news.povray.org
> I can't imagine a scene where the speed-difference would be noticeable.
> (Of course you could invent rather artificial examples, but I'm talking
> about practical scenes.)
Maybe isosurface using only one clip() in it's pattern ?
"Rafal 'Raf256' Maj" <raf### [at] raf256 com> schrieb im Newsbeitrag
news:Xns### [at] 204 213 191 226...
> "Marc-Hendrik Bremer" <Mar### [at] t-online de> wrote in
> news:3d9aec64@news.povray.org
> > There is really no need to build in everythink in the
> > Pov-Code.
> speed ?
> We have i.e. 1 room (inverted box) inside with we have camera, lightsource
> and i.e. white sphere.
> Box is covered with function with 1-3 constructions like
> max(0,min(1,x+y...))
I don't understand what you want to do here (covered? with a pigment, a
normal? an isosurface)? If a color_map of some sort is used, then there's no
need to use a clipping function at all.
> And now we add radiosity - fo reach pixel formula min(max(... must be
> counted about 10..50 times depending on radiosity setting - that can
> probably give 5-15% of render time lost. Hmm I guess I should just add
this
> minmax() function and see is speed improvment notacible :)
The speed increase will strongly depend on the other thinks you use in the
scene. A quick 'n dirty test gave me 0,0000073 seconds for one function call
parsed and evaluated. I don't think, that pov will have to parse the
function for every ray if you use it in a pattern or even an isosurface
(don't know for sure though).
Implement your minmax()-function, if you want to, but if you need only one
day to do it, you will have to use your function quite a lot to get your
time back :-) I'm no programmer at all, so I'm happy about everything that
makes "my life" easier - but if the parser takes longer and longer to parse
even a simple scene, because there are too many keywords to check, it
doesn't make my life easier but harder.
Greetings,
Marc-Hendrik
In article <Xns### [at] 204 213 191 226>,
It'd either be so fast it wouldn't matter or the clip would take such a
small fraction of total evaluation time you wouldn't notice a difference.
You really seem to have no idea how optimization is done...you optimize
slow parts, not simple parts. The clip() function is likely to take only
a very tiny amount of total rendering time, and then in only a small
percentage of scenes. It would be a waste of time to implement it
internally, the time would be better spent with other optimizations,
maybe something like allowing inlining of functions, where POV would
expand a clip() call to the min/max() calls. Or more powerful macros.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
On Wed, 02 Oct 2002 09:05:24 -0400, Rafal 'Raf256' Maj quoth:
>> There is really no need to build in everythink in the Pov-Code.
> speed ?
> lightsource and i.e. white sphere.
> this minmax() function and see is speed improvment notacible :)
You won't gain much speed. For example, I once converted a complicated
isosurface function for clouds to an internal pattern, and only got a
speedup of about 10%. For a simple function such as clip(), you probably
won't be able to measure the speedup.
Mark
Christopher James Huff <chr### [at] mac com> wrote in news:chrishuff-
386### [at] netplex aussie org
So therefore I don't expect any medal of honor from POV-Team for writting
it ;) but this change would prouce a little bit better, or worse POV code ?
It would be same fast, or little bit faster AFAIK ?
And I want to get an idea i.e. by doing some (little) optimization myself.
It's my time so I think I will decide with optimization I want to
implement, ok :) ?
Ok, but I do NOT want to code it ok ? I think I will implement a clip() for
a "warm-up" and to get better along with pov's sources. Maybe inlining
alsow - someday... :)
With files (and best - function names/lines) :
* have formulas for some literal functions like pow(a,b) ? (I want to see
how it's done)
* now what should I do to add my own function (real-function) like i.e.
my_function(a,b) and I want it's formula to be i.e. (a+b) for tests
reasons. I quess I will have to change parser code, and functions code ?
* now I want to add function like my_function(a,b,c) - it should be very
simmilar probably ?
TIA
In article <Xns### [at] 204 213 191 226>, "Rafal 'Raf256' Maj"
Never with the current code, I am sure...
> how it's done)
> simmilar probably ?
<http://www.abx.art.pl/pov/patches/f_triangle.php>
Thorsten
e-mail: tho### [at] trf de
