POV-Ray : Newsgroups : povray.newusers : pigment / finish in union Server Time
19 Sep 2025 06:13:28 EDT (-0400)
  pigment / finish in union (Message 1 to 3 of 3)
Subject: pigment / finish in union
Date: 30 Sep 2002 17:12:00
Message: <Xns9299EBC81E5B5raf256com@204.213.191.226>
Hello,
very simple question :
union {
  #declare a = 0.98;
  #declare b = 0.30;
  cylinder { -y, +y*100, 10 pigment { color rgb <a,b,b> } translate z*0  }
  cylinder { -y, +y*100, 10 pigment { color rgb <a,a,b> } translate z*40 }
  cylinder { -y, +y*100, 10 pigment { color rgb <b,a,b> } translate z*80 }
  finish { specular 0.9 roughness 0.02 reflection .5 } // ((1))
  translate <100,0,0>
shouldn't this code set the ((1)) finish to all 3 cyliders in union,
leaving pigment differnet for each of them ?
Have I to put finish{...} block into each cylinder{...} even it is same for
all objects in union ?
Subject: Re: pigment / finish in union
Date: 30 Sep 2002 17:56:08
Message: <chrishuff-6D6C1F.17532430092002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
No. The finish statement is expanded into a full texture with default
values for anything that isn't specified, which is applied to any
untextured objects in the union (there are none in your example).
Yes. You don't have to specify the whole thing every time, you could
declare it and use the declared finish, but you need a finish block for
each of them. You could also use a declared texture, and modify its
pigment, or use a macro.
http://tag.povray.org/
Date: 1 Oct 2002 04:57:22
Message: <3d996372$1@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in message
> Hello,
> union {
>   #declare a = 0.98;
>   #declare b = 0.30;
>   translate <100,0,0>
Nice idea - the trouble is that your pigment statements are not just pigments -
they are expanded to a full texture (including a finish). Therefore your finish
statement has no effect, since it only applies to untextured objects in the
union.
What you need is:
#declare MyFinish =   finish { specular 0.9 roughness 0.02 reflection .5 }
union {
  #declare a = 0.98;
  #declare b = 0.30;
  cylinder { -y, +y*100, 10 pigment { color rgb <a,b,b> } finish{MyFinish}
translate z*0  }
  cylinder { -y, +y*100, 10 pigment { color rgb <a,a,b> } finish{MyFinish}
translate z*40 }
  cylinder { -y, +y*100, 10 pigment { color rgb <b,a,b> } finish{MyFinish}
translate z*80 }
  translate <100,0,0>
