POV-Ray : Newsgroups : povray.newusers : Something strange is happening to me (again) Server Time
28 May 2026 03:28:05 EDT (-0400)
  Something strange is happening to me (again) (Message 1 to 10 of 13)
Subject: Something strange is happening to me (again)
Date: 20 Oct 2025 03:53:28
Message: <68f5ea78$1@news.povray.org>
Hello,
Let an array of "4D" vectors.
This code works well :
#write ( FH, Array[i].x,",",Array[i].y,",",Array[i].z,",",Array[i].filter )
Now with and array of "5D" vectors.
Base on the same schema i code this :
#write ( FH,
Array[i].x,",",Array[i].y,",",Array[i].z,",",Array[i].filter,",",Array[i].transmit
And i get this error : "Expected 'string', colour identifier found instead".
On <https://wiki.povray.org/content/Reference_Talk:Vector_Expressions>
from Bald Eagle, you can read :
#declare Vector = < 1, 2, 3, 4, 5>;
#declare Fifth_Component = Vector.transmit;// 5
The fifth element corresponds well to the keyword "transmit".
So why did this error occur?
I got around the issue like this :
#declare _x = Array[i].x;
#declare _y = Array[i].y;
#declare _z = Array[i].z;
#declare _f = Array[i].filter;
#declare _t = Array[i].transmit;
#write ( FH, _x,",",_y,",",_z,",",_f,",",_t )
However, I would like to understand what is wrong with my syntax.
Thank you for your help.
kurtz le pirate
compagnie de la banquise
Subject: Re: Something strange is happening to me (again)
Date: 20 Oct 2025 06:49:53
Message: <68f613d1$1@news.povray.org>
Below the contents of a documentation scene I'm adding to the next yuqk
release (R20). What's going on is part of a larger tangle due when and
how the features involved were implemented over time.
Bill P.
// Odd behavior with 'write' and 5D color vectors...
#declare V2 = <1,2>;
#declare V3 = <1,2,3>;
#declare V4 = <1,2,3,4>;
#declare V5 = <1,2,3,4,5>; // Internally this a 'color vector'
#fopen FH "zzz" write
// These are OK in yuqk or in v3.8 beta 2
#write (FH,V3.x,",",V3.y,",",V3.z)
#write (FH,V4.x,",",V4.y,",",V4.z,",",V4.t)
#write (FH,(V5.x),",",(V5.y),",",(V5.z))
#write (FH,(V5.x),",",(V5.y),",",(V5.z)",",(V5.t))
#write (FH,(V5.x),",",(V5.y),",",(V5.z)",",(V5.t)",",(V5.transmit))
#write (FH,V2)
#write (FH,V3)
#write (FH,V4)
// This fails in yuqk and in v3.8 beta 2 because 'write' only
// supports 2D, 3D and 4D vectors.
#if (0)
#write (FH,V5)
// This fails in v3.8 beta 2 because 'write' only supports 2D, 3D
// and 4D vectors. Due how the dot operator works, incorrectly,
// for the v3.8 tuple feature the V5.transmit is first seen as a 5D
// color vector - before it is seen as a float due the dot operator.
#if (0)
#write (FH,V5.transmit)
// These fail in yuqk due fixes with the tuple assignment feature of
// v3.8 which changes how the dot operators are evaluated. The yuqk
// fork always sees 'V5' before it thinks about the dot operator. In
// other words, with yuqk you must wrap all, 5D color vector, element
// to float conversions in ()s with write!
#if (0)
#write (FH,V5.x,",",V5.y,",",V5.z)
// #write (FH,V5.x,",",V5.y,",",V5.z,",",V5.t)
// #write (FH,V5.x,",",V5.y,",",V5.z,",",V5.transmit)
#fclose FH
#error "Stop early"
Bill P.
Date: 20 Oct 2025 07:20:31
Message: <68f61aff$1@news.povray.org>
Le 2025-10-20 à 03:53, kurtz le pirate a écrit :
> Hello,
> #write ( FH,
> Array[i].x,",",Array[i].y,",",Array[i].z,",",Array[i].filter,",",Array[i].transmit )
> instead".
Working from William's reply, I have this workaround :
Replace :
#write (
FH,Array[i].x,",",Array[i].y,",",Array[i].z,",",Array[i].filter,",",Array[i].transmit
With :
#declare Trans = Array[i].transmit;
#write ( FH,
Array[i].x,",",Array[i].y,",",Array[i].z,",",Array[i].filter,",",Trans )
Date: 20 Oct 2025 09:40:32
Message: <68f63bd0$1@news.povray.org>
>> #write ( FH,
> Bill P.
> #write (FH,V2)
> #write (FH,V3)
> #write (FH,V4)
> #if (0)
> #write (FH,V5)
> #end
> #if (0)
> #end
> #if (0)
> #end
> #fclose FH
> #error "Stop early"
> Bill P.
Thanks Bill.
I see "This fails in v3.8 beta 2 because 'write' only supports 2D, 3D
and 4D vectors."
So in a way, it's not coming from me.
Phew!
One more thing to add (or not?) to your to-do list for v4.
kurtz le pirate
Date: 20 Oct 2025 09:42:40
Message: <68f63c50$1@news.povray.org>
>> Hello,
>> #write ( FH,
>> #write ( FH,
>> instead".
> Replace :
> #write
> With :
> #write ( FH,
Yes Alain, shorter as my workaround but in the same spirit.
kurtz le pirate
Date: 20 Oct 2025 10:15:00
Message: <web.68f6435d377e8b3ac330b87125979125@news.povray.org>
Do we have a comprehensive list of unfixed bugs for various POV-Ray features?
It might be helpful to have some method by which we list known limitations and
bugs in the actual documentation until such time that they get fixed.
- BW
Date: 20 Oct 2025 11:50:00
Message: <web.68f659e4377e8b3a17bac71e8ffb8ce3@news.povray.org>
That's what github is for. Once a bug is identified as a bug (here on the forum)
post it and the information gathered on github. Or post it directly on github
and discuss there. Personally I prefer here,
ingo
Date: 20 Oct 2025 12:20:00
Message: <web.68f66104377e8b3ac330b87125979125@news.povray.org>
An expected reply, and exactly the kind of thing I'm trying to avoid.
Just look at the 30-year collection of information that we have here on the
newsgroup.  Too vast, too spread out, and currently unreliably searchable.
And I don't want to go to github and have to then sift through all of that.
What I'd like is a consolidated, up-to-date list that anyone can look at
"at-a-glance" and be able to readily assess the state of every keyword and
primitive, and distribution include file, etc.
Right here on our own, locally-controlled server space.
Because I prefer "here" as well.
I should be able to scroll down to, or search for #read, and only see _existing_
bugs (unless I want to view the bug report and remediation history).  Every new
POV-Ray task should not trigger a new, epic quest.
3rd party stuff is undeniably useful.  However I disdain _reliance_ upon it.
Just look at the Object Collection fiasco.
Here again, I will shamelessly make a plug for some kind of project management
system.
- BW
Date: 20 Oct 2025 12:30:00
Message: <web.68f662cf377e8b3a6ddd22546cde94f1@news.povray.org>
hi,
+1 wrt "here".
a wiki page, with simple "bullet" list ?
regards, jr.
Date: 20 Oct 2025 12:50:00
Message: <web.68f66827377e8b3a17bac71e8ffb8ce3@news.povray.org>
> system.
Github has that and many other tools, but you have to pay.
https://github.com/features/issues I'm not a github user so I know little of it.
I asked their "thing" for a summary:
Copilot said: Here is a summary of the issues
Here is a summary of the issues for POV-Ray, ordered by severity (highest to
lowest). Please note: this is based on public issue titles, labels, and visible
project maintainers.
Critical Bugs & Vulnerabilities
    Potential Vulnerabilities (Cloned Functions)
        Fix potential vulnerable cloned function
        Fix potential vulnerable cloned functions
        Fix potential vulnerable cloned function Severity: Security-related,
likely the most urgent.
    Bug: Functionality Failure
        [BUG] function "trace" fails to find intersections in distances of more
than 10⁷ units Severity: Major feature broken for large distances.
    Build/Compatibility Failures
        [BUILD][UNIX] Failure on macOS w/ Xcode 16.4, error: unknown type name
'Fixed'
        [BUILD][UNIX] Build fails with strict-aliasing violations
        [BUILD][UNIX] Test for Boost Libraries fail on Apple silicon (Homebrew
path change) Severity: Prevents build on certain platforms.
    Bug: Parse/Error Handling
        [BUG] Parse error when using povray built by GCC 13, no error with GCC
12
        [BUG] doesn't give an error if a polygon is not 2D
        [BUG][UNIX] Failed to parse command line option with space in filename
Severity: Could lead to silent failures or unpredictable behavior.
    Bug: Memory/Allocation
        Assigned interior causes a bad allocation error Severity: May cause
crashes or data corruption.
    Bug: Incorrect Rendering
        Photons do not work properly with true inverse power fading
        Option "Keep Single Instance" is not working for *.inc files
        Error in POV-RAY output generated from Project Chrono Demo Severity: Can
result in incorrect output or broken features.
Medium Severity
    Performance/Optimization
        Usage of Enhanced Math Library for better performance
        AVX512 version for POVRAY Severity: Performance improvements, not
critical but useful.
    Feature Requests: Important for Users
        [FEATURE] support all Opentype font formats
        [FEATURE] LaTeX support
        Can we develop POV-RayMCP similar to BlenderMCP? Severity: Not bugs, but
could be important for project adoption.
Low Severity / Minor Issues
    Minor Bugs and UI Issues
        Debug string is not displayed in console if start with more than 14
hyphens
        Need to run POVRAY on a single thread
        Updates to screen.inc
        Issue a parse warning for out-of-domain arguments to the srgb keywords
        remove unecessary nullptr check before 'delete' and 'delete[]'
        Apply translate and rotate to user_defined cameras.
        Fixing some missing stuff in VS 2022
        What about 3.7 branch ? Severity: Minor bugs, enhancements, or
low-priority tasks.
Note:
    This list is based on 30 issues (API limit). For a complete and up-to-date
list, view all POV-Ray issues on GitHub.
on user impact, security, or strategic goals.
    If you want a more detailed triage or deeper analysis of a specific issue,
let me know!
ingo
