POV-Ray : Newsgroups : povray.newusers : Something strange is happening to me (again) Server Time
14 Mar 2026 09:04:55 EDT (-0400)
  Something strange is happening to me (again) (Message 11 to 13 of 13)
Subject: Re: Something strange is happening to me (again)
Date: 20 Oct 2025 13:20:00
Message: <web.68f66e29377e8b3ac330b87125979125@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> +1 wrt "here".
> a wiki page, with simple "bullet" list ?
This would likely suffice, if there were someone to compile the present list,
and it were editable by a sufficiently wide user list.
Maybe a talk page or something.
I could likely write a simple spreadsheet to list keyword, file, macro,
whatever, who reported the bug, the link to the thread, who volunteered to fix
it, date, present status, etc.
That could be updated periodically to reflect the state of things.
Or maybe there's a way to format data on the wiki for retrieval by a spreadsheet
so that any local copies of the spreadsheet that people download can get
updated.
A record of the code development history - even as a simple text file - ought to
be provided in the distribution.
"I'm putting together a team.  People with special abilities."
- BW
Date: 20 Oct 2025 13:50:00
Message: <web.68f67585377e8b3ac330b87125979125@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 10/20/25 03:53, kurtz le pirate wrote:
> > Let an array of "4D" vectors.
> > This code works well :
> > #write ( FH, Array[i].x,",",Array[i].y,",",Array[i].z,",",Array[i].filter )
> Below the contents of a documentation scene I'm adding to the next yuqk
> release (R20). What's going on is part of a larger tangle due when and
> how the features involved were implemented over time.
> Bill P.
> // Odd behavior with 'write' and 5D color vectors...
> #declare V2 = <1,2>;
> #declare V3 = <1,2,3>;
> #declare V4 = <1,2,3,4>;
> #declare V5 = <1,2,3,4,5>; // Internally this a 'color vector'
> #fopen FH "zzz" write
> // These are OK in yuqk or in v3.8 beta 2
> #write (FH,V3.x,",",V3.y,",",V3.z)
> #write (FH,V4.x,",",V4.y,",",V4.z,",",V4.t)
> #write (FH,(V5.x),",",(V5.y),",",(V5.z))
> #write (FH,(V5.x),",",(V5.y),",",(V5.z)",",(V5.t))
> #write (FH,(V5.x),",",(V5.y),",",(V5.z)",",(V5.t)",",(V5.transmit))
> #write (FH,V2)
> #write (FH,V3)
> #write (FH,V4)
> // This fails in yuqk and in v3.8 beta 2 because 'write' only
> // supports 2D, 3D and 4D vectors.
> #if (0)
> #write (FH,V5)
> #end
> // This fails in v3.8 beta 2 because 'write' only supports 2D, 3D
> // and 4D vectors. Due how the dot operator works, incorrectly,
> // for the v3.8 tuple feature the V5.transmit is first seen as a 5D
> // color vector - before it is seen as a float due the dot operator.
> #if (0)
> #write (FH,V5.transmit)
> #end
> // These fail in yuqk due fixes with the tuple assignment feature of
> // v3.8 which changes how the dot operators are evaluated. The yuqk
> // fork always sees 'V5' before it thinks about the dot operator. In
> // other words, with yuqk you must wrap all, 5D color vector, element
> // to float conversions in ()s with write!
> #if (0)
> #write (FH,V5.x,",",V5.y,",",V5.z)
> // #write (FH,V5.x,",",V5.y,",",V5.z,",",V5.t)
> // #write (FH,V5.x,",",V5.y,",",V5.z,",",V5.transmit)
> #end
> #fclose FH
> #error "Stop early"
> Bill P.
So,
I'm curious about all of this.
There seems to be an awful lot of bouncing around under the hood, and a fair
amount of replicated code for things like splines, etc.
How are the vector components stored, and why do they need to be recast into
floats?
I see that there is no 5d vector defined in math/vector.h - it is in
base/colour.h
Can we somehow consolidate/unify the colors and the vectors, or do we want to
somehow completely separate them with a means to interconvert as per clipka?
#write converts everything to strings first?
Date: 20 Oct 2025 14:50:00
Message: <web.68f6833a377e8b3a6ddd22546cde94f1@news.povray.org>
hi,
to begin with, I think, getting "the list" going is priority, as one of your
pages perhaps.  medium to long-term, and when the details are fixed, we can move
the page.
> updated.
we do have tables.  I also think that the list(ing) should be kept simple,
mostly just a reference/index providing links to the details (like "who
volunteered").
back when s/wares used to provide a 'ChangeLog' file, for the exact purpose.
regards, jr.
