POV-Ray : Newsgroups : povray.newusers : isosurface perturbation Server Time
10 Oct 2025 07:09:20 EDT (-0400)
  isosurface perturbation (Message 1 to 4 of 4)
Subject: isosurface perturbation
Date: 26 May 2025 13:40:51
Message: <6834a7a3@news.povray.org>
Hello,
Suppose we have a define a block with an isosurface whose surface is
perturbed by a pigment function like that in a macro :
#macro CarvedRocks(xDim, yDim, zDim, Rad)
isosurface {
  function {
   f_rounded_box(x, y, z, Rad, xDim, yDim, zDim)
   -f_agate(x,y,z)
I can carve multiple stones :
#declare block1 = CarvedRocks(x1, y1, z1, Rad)
#declare block2 = CarvedRocks(x1, y1, z2, Rad)
The problem is that the disturbance is the same for all blocks.
This is not illogical, since the agate function always returns the same
values.
Hence my question: how to obtain different blocks with the same agate
(or other) function ?
Traditionally, by applying pigment before translations, box appear
different. But for an isosurface, I don't see how this can be done.
Any ideas ?
THanks
kurtz le pirate
compagnie de la banquise
Subject: Re: isosurface perturbation
Date: 26 May 2025 14:00:00
Message: <web.6834ab04f8393ea59c0b49ce25979125@news.povray.org>
kurtz le pirate <kur### [at] freefr> wrote:
> Hello,
> isosurface {
>   function {
>    -f_agate(x,y,z)
> #end
> values.
It gets done in "exactly" the same way as you do with regular objects - you just
use math, not keywords to do it.
If you want to translate your box, you add or subtract to the x, y, or z going
into the function.
f_rounded_box(x-TransX, y-TransY, z-TransZ, Rad, xDim, yDim, zDim)
Same with the pigment function.
f_agate(x-TransX, y-TransY, z-TransZ)
If you wanted to use a keyword, you could undef your pigment function, and use
function (x, y, z, X, Y, Z) {pigment {agate translate <X, Y, Z>}}
- BW
Date: 26 May 2025 23:05:58
Message: <68352c16$1@news.povray.org>
Le 2025-05-26 à 13:40, kurtz le pirate a écrit :
> Hello,
> isosurface {
>   function {
>    -f_agate(x,y,z)
> #end
> values.
> Any ideas ?
> THanks
You can feed the function some disturbed coordinates.
isosurface{f_leopar(x+f_granite(x,y,z), y+f_granite(x,y,z),
y+f_granite(x,y,z)), contained_by{box{<-1000, -1.2, -1000><1000, 1.2,
1000>}} <OtherIsodusfaceParameters>}
Date: 28 May 2025 04:29:40
Message: <6836c974$1@news.povray.org>
Thank you for your answers.
They gave me some new ideas.
kurtz le pirate
