POV-Ray : Newsgroups : povray.newusers : Trouble cutting objects Server Time
12 Jul 2026 20:41:54 EDT (-0400)
  Trouble cutting objects (Message 1 to 10 of 10)
Subject: Trouble cutting objects
Date: 23 Feb 2025 05:17:46
Message: <67baf5ca$1@news.povray.org>
In the attached image (this is a view from below).
In the center, the object built from the union of a cylinder and a mesh.
On the right, the same object “cut” at the base by a plane
difference {
  object { Screw }
  plane { y,0 }
And then, as you can see, something “weird” happens.
If I make the difference with a box, it's the same thing.
And, if instead of “cutting” at the bottom, I cut at the top, the same
thing happens. It can't be a problem of surface coincidence. The values
are quite different, in fact.
Do you have any ideas for solving this issue ?
nb: the vertical black line with the balls is simply  gauge to check the
screw pitch and has nothing to do with the problem.
kurtz le pirate
compagnie de la banquise
Download 'issue.jpg' (61 KB)
Preview of image 'issue.jpg'
Subject: Re: Trouble cutting objects
Date: 23 Feb 2025 05:44:11
Message: <67bafbfb$1@news.povray.org>
Le 23/02/2025 à 11:17, kurtz le pirate a écrit :
> Hi,
> difference {
>   object { Screw }
>   plane { y,0 }
Bonjour/Hello
When you try to make a difference or merge CSG operation with isosurface
objects, you should use the "max trace 'intersections number'" (to write
in the isosurface statement at the end ideally) keyword so POVRay
doesn't stop at the first collision between rays and the isosurface
object. So far, I don't know if you used the max_trace keyword because
we don't have all the code.
Date: 23 Feb 2025 07:36:05
Message: <67bb1635$1@news.povray.org>
What version of POV-Ray are you using? There were v3.8 development
versions over time with difference issues.
If not a problematic version of POV-Ray, I'd bet next on something with
the mesh, but...?
I tried a simple cylinder scene and things look OK test one each of the
v3.7 and v3.8 compiles I have in hand.
#declare Cyl00 = cylinder {
     <0,-0.1,0>, <0,1,0>, 0.2
     pigment { rgb <0.3,0.5,0.6> }
     finish { emission 0.2 }
difference {
   object { Cyl00 translate <-0.7,0,0> }
   plane { y,0 }
   cutaway_textures
object { Cyl00 }
Bill P.
Download 'tmp38.png' (28 KB)
Preview of image 'tmp38.png'
Date: 23 Feb 2025 09:12:05
Message: <67bb2cb5$1@news.povray.org>
On 23/02/2025 11:44, antoine wrote:
> Bonjour/Hello
Isosurface ?
There is no isosurface here ;)
kurtz le pirate
Date: 23 Feb 2025 09:30:59
Message: <67bb3123$1@news.povray.org>
Persistence of Vision(tm) Ray Tracer Version 3.8.0-beta.2.unofficial (
Compiler: Apple LLVM 12.0.5 (clang-1205.0.22.11))
> the mesh, but...?
Yes, me too
But the mesh is simple "concatenation" of triangles.
The max/min values off the mesh are :
Max = < 7.00, 31.00, 7.00>
Min = <-7.00, -1.00, -7.00>
These values are consistent with the calculations and the drawing.
No point of the triangles has a value greater than the cylinder
containing the mesh
> difference {
>    plane { y,0 }
>    cutaway_textures
> object { Cyl00 }
> Bill P.
Yes, with simple objects, no issue.
I made others tests. The base object ranges from -1 to 31.
If I try with another y value (say 5) i get the same issue at y = 5.0
has you can see.
I also added the cylinder object limits.
I'm still trying to figure out what's so special about this mesh ...
kurtz le pirate
Download 'issue2.jpg' (62 KB)
Preview of image 'issue2.jpg'
Date: 23 Feb 2025 15:27:04
Message: <67bb8498$1@news.povray.org>
>> with the mesh, but...?
> Yes, me too
> containing the mesh
I'll take you to mean no point of the triangles has a value >= a surface
of the cylinder containing the mesh.
And, you've specified an inside_vector <> in your mesh definition? One
NOT axis aligned (<0,0,1>) as recommended by our documentation at:
   https://wiki.povray.org/content/Reference:Mesh#Solid_Mesh
Use something more random and unlikely to run near parallel with any
triangle's surface in your mesh (*) - there are some epsilon tolerance
values when testing whether inside the mesh.
Bill P.
(*)- There is too a narrow / unlikely potential bug when translating a
mesh with an originally valid inside_vector, which is fixed in the yuqk
fork.
Date: 23 Feb 2025 16:17:01
Message: <67bb904d$1@news.povray.org>
> the mesh, but...?
Another upfront question is: Are you sure the mesh is really closed?
The 'Solid' part of Constructive Solid Geometry is often important -
though you can get away with quite a bit in practice.
And, have you tried an intersection{} instead?
intersection {
   object { Screw }
   plane { -y, 0 }
Bill P.
Date: 24 Feb 2025 06:30:45
Message: <67bc5865$1@news.povray.org>
yes
Ho yes, I tried several inside_vector without further luck.
A very good point.
I also think the problem lies here
> Bill P.
> fork.
Here, the same things rendered with yuqk* :(
* : look in p.b.programming. I have strange errors with yuqk
kurtz le pirate
Download 'screew_yuqk.png' (63 KB)
Preview of image 'screew_yuqk.png'
Subject: Re: Trouble cutting objects (I'm going crazy)
Date: 24 Feb 2025 10:32:45
Message: <67bc911d$1@news.povray.org>
> intersection {
>    object { Screw }
>    plane { -y, 0 }
I rebuilt yuqk with the right option (THANKS Jr).
I went back to my 3.8 source code, added the right lines for version
3.8.0-x.yuqk_a5c25dda and re-rendered. As expected, the names of my
variables are accepted without any problem.
I'm happy.
Attached is a summary of this "magnificent" scene.
Do you see the problem ?
The issue I mentioned earlier has disappeared !
What is the relationship between the "--disable-no-lc-identifiers" and
the difference  { } opération ?
A new leap into the 5th dimension :(
kurtz le pirate
Download 'vis_yuqk_ok.png' (85 KB)
Preview of image 'vis_yuqk_ok.png'
Date: 25 Feb 2025 05:11:11
Message: <67bd973f$1@news.povray.org>
> A new leap into the 5th dimension 🙁
"Don't worry, be happy?"
No idea why behavior might have changed. It' very unlikely to be related
to "--disable-no-lc-identifiers", but stranger things have happened...
Bill (Already crazy) P.
