POV-Ray : Newsgroups : povray.newusers : Image function Server Time
27 Jul 2024 14:19:05 EDT (-0400)
  Image function (Message 1 to 10 of 10)
Subject: Image function
Date: 28 May 2023 10:49:57
Message: <64736a15$1@news.povray.org>
Hello,
I'm racking my brain over this problem :
I'd like to have a function that can give me the color of a pixel in an
image (the equivalent of "eval_pigment") to fill a plane.
I've tried a lot of things but none of them work.
What I would like :
plane {
 y, 0
 pigment { color imageFunction(x,y,z) }
With the function like that :
#declare imageFunction = function {
  image_map { jpeg imageName }
  rotate -x*90
  translate <-0.5, 0, -0.5>
  scale <imageWidth, 1, imageHeight>
Of corse, this does not work and i get parse errors but the idea is here.
So can you tell me if this "kind of thing" is possible or not before I
go *crazy* ?
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Image function
Date: 28 May 2023 11:22:48
Message: <647371c8$1@news.povray.org>
Op 28-5-2023 om 16:49 schreef kurtz le pirate:
> Hello,
Why not use eval_pigment? See:
https://news.povray.org/povray.binaries.images/thread/%3Cweb.52ede41cd6fcc84f7a3e03fe0%40news.povray.org%3E/?mtop=395729
I must have the macro somewhere... I shall send it tomorrow from my
other machine.
Date: 28 May 2023 16:10:00
Message: <web.6473b4558a5f67eb1f9dae3025979125@news.povray.org>
Once again, I'm asking WHY?
Kenneth tried to do this circular process a while back - but if all you're doing
is tiling a plane with an image, then just use an image_map pigment and don't
specify "once".
If you do, however, have some future use for the function version, then you need
to invoke it like this:
plane {
  y, 0
  pigment { function { imageFunction (x,y,z) } }
eval_pigment is just a macro wrapper for the same kinda thing, which means that
will be an extra layer, and another layer on top of that to un-macro-ify it (if
even possible) for use in the way you want.
- BE
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hello,
> What I would like :
> plane {
>  y, 0
>  pigment {
>   rotate -x*90
> go *crazy* ?
> Kurtz le pirate
Date: 29 May 2023 02:30:33
Message: <64744689$1@news.povray.org>
Op 28/05/2023 om 17:22 schreef Thomas de Groot:
>> Hello,
> other machine.
I don't know if this is what you want to do, but provide an image map
and play with this test scene...
Download 'eval_pigmenttest_carpet.pov.txt' (5 KB)
Date: 29 May 2023 12:10:57
Message: <6474ce91@news.povray.org>
apologies...
I didn't describe what I wanted to do very well.
I'll try to be clearer.
a) I recover the color of a point <x,0,z> of a source image.
b) I transform this point into a new point <x1,0,z1>.
c) I give this new point the color taken in a)
In fact, I already have a code that does this, but only with the checker
pattern. Not very sexy !
For the moment the plan is drawn like this :
plane {
  y,0
  pigment { function { fnPigment(x,z) } }
hence my request for a function()
Instead of the checker, the original distorted image.
The "geometric" transformation is the result of applying function.
Two examples with f(z) = z^2 and f(z) = sin(z)/(z+1).
Brighter ?
ps : I'm going to watch "Eval_pigmentTest_carpet.pov". Thanks Thomas
Kurtz le pirate
Download 'map01_cfunctions_9.png' (21 KB) Download 'map01_cfunctions_1.png' (33 KB)
Preview of image 'map01_cfunctions_9.png'
Preview of image 'map01_cfunctions_1.png'
Date: 29 May 2023 13:55:00
Message: <web.6474e69a8a5f67eb1f9dae3025979125@news.povray.org>
> apologies...
Ah, excellent.
This makes much more sense now.
> Brighter ?
Much better.
Have coded a geometric inversion function?   I would be highly interested in
that for use with Clifford tori and such.
Anyway, here's what I think you need to do if you want to modify an image_map
using a function, and still have the full color.
Then all you have to do is modify the function.
#version 3.8;
global_settings {assumed_gamma 1.0}
default {finish {diffuse 1}}
// +am3 +a0.01 +ac0.90 +r3
 location <0, 5, -0.01>
 up y
 look_at <0, 0, 0>
light_source {<0, 100, 0> rgb 1.0}
sky_sphere {pigment {rgb 1}}
#declare ImageMap = function {pigment {image_map {png "plasma2.png"} rotate
x*90} }
#declare FullColorTexture =
          average
          pigment_map {
                  function { ImageMap (x, y, z).red }
                  color_map {
                      [ 0 red 0 ]
                      [ 1 red 5 ]
                  function { ImageMap (x, y, z).green }
                  color_map {
                      [ 0 green 0 ]
                      [ 1 green 5 ]
                  function { ImageMap (x, y, z).blue }
                  color_map {
                      [ 0 blue 0 ]
                      [ 1 blue 5 ]
                  function { ImageMap (x, y, z).filter }
                  color_map {
                      [ 0 blue 0 ]
                      [ 1 blue 5 ]
                  function { ImageMap (x, y, z).transmit }
                  color_map {
                      [ 0 blue 0 ]
                      [ 1 blue 5 ]
    } // end pigment map
   } // end pigment
  } // end layered texture
plane {
 y, 0
 texture {FullColorTexture }
Hope that works the way you want.
- BW
Download 'imagemapfunction.pov.dat' (2 KB)
Date: 29 May 2023 20:25:00
Message: <web.647541d58a5f67eb8991e8e489db30a9@news.povray.org>
> apologies...
> plane {
>   y,0
Hi Kurtz
The code here may be relevant for what you are trying to achieve:
Subject: Source code for "Using functions to distort images"
Date: 2006-05-12 18:48:59
http://news.povray.org/povray.text.scene-files/thread/%3C4470ee5b%40news.povray.org%3E
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 30 May 2023 13:40:00
Message: <web.647633ec8a5f67ebb49d80446cde94f1@news.povray.org>
hi,
neat, thanks for posting this link.
regards, jr.
Date: 30 May 2023 20:20:00
Message: <web.647691b78a5f67eba9e5460e89db30a9@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
No problem jr. I am glad if I can help with solving someone's problem.
Tor Olav
http://subcube.com
Date: 1 Jun 2023 12:44:28
Message: <6478caec$1@news.povray.org>
Thanks guys. Two leads to explore
and in 2006... i don't think i already knew "functions" !
Kurtz le pirate
