POV-Ray : Newsgroups : povray.newusers : Ignorance rules! Server Time
21 Mar 2026 20:25:02 EDT (-0400)
  Ignorance rules! (Message 24 to 28 of 28)
Subject: Re: Ignorance rules!
Date: 7 Feb 2021 17:25:05
Message: <602068c1@news.povray.org>
On 6/26/20 7:05 PM, Thorsten wrote:
>> It's easy to forget while playing with code today that those who
>> created POV-Ray were working in a much tougher, unstable environment.
>> Plus we now have ready access to so much more information - Wikipedia,
>> papers, on line code, etc.
> Ah, the same things existed back then. They were called books ;-)
    And we can call 911-COMPU$ERVE :)
http://weblog.mixart-myrys.org/?post/2021/01/Laissez-nous-exister-%21
Date: 26 May 2021 21:23:06
Message: <60aef47a$1@news.povray.org>
Am 23.06.2020 um 19:25 schrieb Cousin Ricky:
> On 2020-06-23 7:28 AM (-4), William F Pokorny wrote:
>> We have the convention today users should not declare IDs with lower
>> case characters because such things might become, or might already be,
>> SDL keywords. What I'm thinking about for povr is adding checking such
>> that users cannot declare/local a name with only (lower case ascii, _)
>> characters. #declare _a =... would be a parsing error.
>> With this in place, I think it would then be the case we could always
>> use something like _<lowercase_parm> for all our parameters without
>> worry of collisions. The _ leading character would never be part of a
>> keyword.
>> Am I missing something with this planned approach?
Been there. Done that.
Curesed a lot.
> I suppose it could work.  It could potentially break old scenes, but I
> don't suppose many such scenes exist.  None of the stock include files
> have any such names that I can find.
Look harder.
`functions.inc` is what made me put the idea on the back burner.
Date: 26 May 2021 22:58:47
Message: <60af0ae7$1@news.povray.org>
Am 24.06.2020 um 19:53 schrieb William F Pokorny:
> (4) - And, yep. I don't like the DBL, SNGL in our source code since
> v1.0. Or the PRECISE_FLOAT Christoph asked me to add to a pull request
> years back which then never got adopted. PRECISE_FLOAT now needs to be
> yanked at some point from povr and I'd like to drop DBL and SNGL too.
I'm trying to jog my memory here to recall what that PRECISE_FLOAT was
all about, but for the love of it I can't find no reference to it,
except mentions by you yourself: One in 2019-02-17 in povray.beta-test
where you posted a snippet apparently from a custom
`polynomialsolver.cpp` where it appears in a comment, and one in a pull
request from LeForgeron, titled "fix for FS324, regression on triangle"
(pull request #358), where you mentioned "the new PRECISE_FLOAT compile
hook" on 2019-06-06.
Can you help me out which pull request of yours that would have been,
for which I suggested the use of PRECISE_FLOAT?
The Interwebkraken knows nothing else about it, GitHub can't seem to dig
it up, and even in all my dozen unpublished half-finished branches that
spun off at different times in history and still reside on my computer,
none of them seems to contain the character sequence "PRECISE_FLOAT".
Is there a publicly accessible repo for your povr branch? Seeing where
you're using the thing might bring my memory back up to speed.
Date: 27 May 2021 05:57:26
Message: <60af6d06$1@news.povray.org>
Related to selective use of long doubles where the hardware supports
80/96 bits or more.
There is today no value to you or the POV-Ray code mainstream to dig
into this. It's my code base stuck with something once thought might be
of value which - knowing what I know today - isn't. It doesn't hurt
anything other than my code's esthetics to have it sitting in there. It
just bugs me that it is there.
Bill P.
Date: 27 May 2021 06:04:42
Message: <60af6eba$1@news.povray.org>
>>> be, SDL keywords. What I'm thinking about for povr is adding checking
>>> such that users cannot declare/local a name with only (lower case
>>> ascii, _) characters. #declare _a =... would be a parsing error.
>>> keyword.
> Curesed a lot.
> Look harder.
Yes, there's that and more for complications. I've had some success with
it and it's how I've been running day to day for near a year now(1).
Twiddle with the hacked in code now and again as I pick up some detail -
recently performance impacts doing millions of calls to macros. Made it
better, but, thinking now even when compiled in there should perhaps be
a run time switch - but given how our macros work even simple that would
be seen performance wise in the worst cases.
Today, I'd say it'll stay in as a configure option for sure, but we'll see.
Bill P.
(1) - It lines up with my coding style/aim where it won't with all.
