POV-Ray : Newsgroups : povray.newusers : can't i rotate a pigment? Server Time
14 Dec 2025 16:52:46 EST (-0500)
  can't i rotate a pigment? (Message 1 to 10 of 14)
Subject: can't i rotate a pigment?
Date: 7 May 2015 04:34:48
Message: <554b23a8$1@news.povray.org>
I have a scene with
	mesh2 {
	        pigment { Tufte rotate N*y }
but the pigment does not rotate.  (Tufte is my own creation.)
Have I forgotten something?
*\\* Anton Sherwood *\\* www.bendwavy.org
Subject: Re: can't i rotate a pigment?
Date: 7 May 2015 07:42:52
Message: <554b4fbc$1@news.povray.org>
On 7-5-2015 10:34, Anton Sherwood wrote:
> I have a scene with
>      mesh2 {
There is no reason why it should not, imo. We need a bit more info
though. First of all, is the mesh2 uv_mapped? From the basic
construction of your code I suppose not, but...
Date: 7 May 2015 13:16:36
Message: <554b9df4$1@news.povray.org>
D'oh!  Tufte is made of "slope"s; one can understand that
rotating it might not work.  I'll try this:
	object {
		rotate -N*y
		pigment { Tufte }
		rotate N*y
Date: 7 May 2015 14:04:55
Message: <554ba947@news.povray.org>
On 2015-5-07 10:16, Anton Sherwood wrote:
> I'll try this:
> 	object {
> 		rotate -N*y
> 		pigment { Tufte }
> 		rotate N*y
No luck.
Date: 7 May 2015 16:11:32
Message: <554bc6f4$1@news.povray.org>
>> I'll try this:
>>     object {
>>         rotate -N*y
>>         pigment { Tufte }
>>         rotate N*y
> No luck.
Try changing the direction vector
   slope {
     < 0.500, 0.000, 0.500 >  // <- Direction
   color_map {
     [0.000 rgbft <1.000,0.000,0.000,0.000,0.000>]
     [0.534 rgbft <0.000,1.000,0.000,0.000,0.000>]
     [1.000 rgbft <0.000,0.000,1.000,0.000,0.000>]
Regards
Date: 8 May 2015 02:58:43
Message: <554c5ea3$1@news.povray.org>
>> I'll try this:
>>     object {
>>         rotate -N*y
>>         pigment { Tufte }
>>         rotate N*y
> No luck.
No surprise: You rotate /the object/ a certain value around the y-axis,
apply the pigment, rotate the object back the same value. You have not
rotated /the pigment/ itself.
However, if the pigment is a slope pattern (along y-axis I suppose) I do
not expect much to happen if you rotate it around the y-axis in any case.
Date: 8 May 2015 03:18:00
Message: <554c6328@news.povray.org>
Why not?  Generally
	object { ...
		texture { foo }
		translate ...
is not the same as
	object { ...
		translate ...
		texture { foo }
> I do not expect much to happen if you rotate it around the y-axis
> in any case.
Not even if it's built of slopes along, say, some other vector(s)?
Download 'tufte.inc.txt' (1 KB)
Date: 8 May 2015 03:19:14
Message: <554c6372$1@news.povray.org>
As there's only one object in the scene, I sidestepped the problem by
rotating the object *and* the camera while letting the pigment stay put.
Date: 8 May 2015 03:27:21
Message: <554c6559$1@news.povray.org>
> Why not?  Generally
>      object { ...
>          texture { foo }
>          translate ...
> is not the same as
>      object { ...
>          translate ...
>          texture { foo }
Hmm yes. I stand corrected for that one :-)
>> in any case.
You are tickling the limits of my knowledge ;-)  Slope is a difficult
pattern to use in my experience and I always need a lot of
experimentation to get it right.
I shall need to make a test scene to see what happens. Back soon.
Date: 8 May 2015 03:54:46
Message: <554c6bc6$1@news.povray.org>
After testing, I can confirm that it is not possible to rotate a slope
pattern, in contrast to other patterns. Even more puzzling, I can
confirm that this is true too when applying the pigment and then
rotating the object: the pigment remains unchanged and does not rotate
with the object.
I do not know if this is a bug or is intentional. If the latest case,
the documentation does not mention it while at the same time indicating
the use of Pigment Modifiers in the example.
I believe we need the voice of an expert now.
