POV-Ray : Newsgroups : povray.newusers : issue rendering demo files Server Time
15 Apr 2025 17:09:36 EDT (-0400)
  issue rendering demo files (Message 1 to 10 of 12)
Subject: issue rendering demo files
Date: 1 Jun 2014 06:04:29
Message: <538afaad@news.povray.org>
hello,
on the /scenes/advanced/blocks, the 'stackertransp.pov' demo file hang
with this error :
"makestacks.inc" line 24 - Parse Error: Expected 'numeric expression',
undeclared identifier 'AspectRatio' found instead
the code is :
#declare Screen= // pseudo screen to test the visibility of an object
   mesh{
     triangle{0,x,x+y}
     triangle{0,y,x+y}
     translate -0.5*(x+y)
     scale <AspectRatio,1,1> <-- ligne 24.
     translate CamZoom*z
     matrix < CamR.x,  CamR.y,  CamR.z,
              CamU.x,  CamU.y,  CamU.z,
              CamD.x,  CamD.y,  CamD.z,
              CamLoc.x,CamLoc.y,CamLoc.z >
in the original 'visibility test' from thomas de groot, there is an
'AspectRatio' declared var.
//--start code--
#declare CamLoc = <0, .3, 0>;
#declare CamEye = <0.0, 6,  0.0>;
#declare CamSky = y;
#declare AspectRatio = 640/1000;
#declare CamZoom = 1.5;
   location  CamLoc
   direction z*CamZoom
   right     x*AspectRatio
   look_at   CamEye
and the modified code from gilles tran use this var but it's not declared...
if i remember good, in mac megapov, there is two vars 'image_height' and
'image_width' and AspectRatio can be calculated by image_height/image_width.
how to deal now with povray 3.7 ?
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: issue rendering demo files
Date: 1 Jun 2014 07:21:06
Message: <538b0ca2$1@news.povray.org>
This seems to be an oversight indeed. Add:
#declare AspectRatio=image_height/image_width;
to makestacks.inc before the #declare Screen= line.
Date: 1 Jun 2014 07:44:52
Message: <538b1234$1@news.povray.org>
> Thomas
Strange stackertransp.pov renders fine on my setup. Which is new and has
no library paths set. Having said that povray.ini has none setbut the
message pane says that it does.
I cannot see where the Windows/fonts and PovRay\ver 3.7\include
paths are defined.
Regards
Date: 1 Jun 2014 14:25:13
Message: <538b7009@news.povray.org>
>> Thomas
> paths are defined.
Those two paths are default paths. They are defined during the install
or automaticaly generated the first POV-Ray is executed if they are not
previously defined. The font folder path is taken from the system path.
The image_height and image_width are global variables available at least
since version 3.6.0.
Date: 1 Jun 2014 14:48:19
Message: <538b7573$1@news.povray.org>
Thanks, I thought it must be something like that. Too lazy to search the
registry, me.
It begs the question, why Kurtz le pirate got an "undeclared identifier"
error.
I couldn't find that in the docs. :-(
Regards
I solemnly promise to kick the next angle, I see.
Date: 2 Jun 2014 03:12:39
Message: <538c23e7$1@news.povray.org>
> registry, me.
> error.
Well, if you run stackertransp.pov right out of the box you just read
the stacks.inc file already provided.
If you make WriteFile = true;  then you will invoke makestacks.inc were
the missing declare should be. Alternatively, you also can declare
AspectRatio /before/ including makestacks.inc
Date: 2 Jun 2014 03:42:04
Message: <538c2acc$1@news.povray.org>
>> registry, me.
>> error.
Thanks Thomas,
To be honest, it was more idle curiosity. I didn't even read the file.
Just searched for AspectRatio
Regards
Date: 2 Jun 2014 07:08:42
Message: <538c5b3a$1@news.povray.org>
On 2-6-2014 9:42, Stephen wrote:
> Thanks Thomas,
Curiosity kills the cat ;-)
Date: 2 Jun 2014 15:12:47
Message: <538cccaf$1@news.povray.org>
>> Thanks Thomas,
Idle curiosity makes it sit back and look contemptuous. ;-)
Regards
Date: 3 Jun 2014 03:22:50
Message: <538d77ca$1@news.povray.org>
>>> Thanks Thomas,
LOL
Which the neighbours' cat was just doing the other day, watching me mow
the grass (and not doing a very good job - too long).
