POV-Ray : Newsgroups : povray.newusers : Losing my mind Server Time
6 Aug 2025 04:37:44 EDT (-0400)
  Losing my mind (Message 1 to 5 of 5)
Subject: Losing my mind
Date: 1 Apr 2014 23:10:59
Message: <533b7fc3$1@news.povray.org>
Ok, I've been trying to reproduce the stereographic image on:
http://xahlee.info/3d/illus_geometry.html
I got my sphere made up of a grid formed by rings originating at the
"north pole" of the sphere, and radiating outwards from there in 2 fans,
one rotating along the z-axis, and one along the x-axis.
Got my light source near the North pole.
Got my transparent square to fill a space in the grid.
I cannot for the life of me figure out why my cylinders do not line up
with the intersection points on the grid.  The farther they're rotated,
the more they are off.  I've checked, and double checked, and quintuple
checked, and only rendered parts of the scene, and even switched to an
orthographic camera to eliminate any visual confusion arising from
perspective / optical illusions.
Maybe I'm old, maybe I'm tired, maybe I'm just geometrically incapable.
I dunno.
It seems to me that if I take a box that's centered on the origin,
rotate it, and translate it by y* the radius of the sphere, and then
take a cylinder that originates at the origin and extends downwards, and
perform the same operations, that they should be aligned.
But they are not.  And I can't figure out why.  :(
SDL:
#declare Size = 100;
#declare Height = 100;
#declare Spacing = 300;
#declare Axis = 2;
light_source { < 0, Height + 95, -150>, rgb <1,1,1>}
#declare Axes = union {
cylinder {<0, 0, 0>, <Size, 0, 0>,  Axis texture {pigment {color Red}
  finish {ambient 0.5} } }
cylinder {<0, 0, 0>, <0, Size, 0>,  Axis texture {pigment {color Green}
cylinder {<0, 0, 0>, <0, 0, -Size>, Axis texture {pigment {color Yellow}
camera { orthographic location <0, Height, -500> look_at <0, Height/2,
-50> }
#declare WIP = union { //object {Axes}
#declare Radius = 100;
#declare Thickness = 1;
#declare Step = 5;
sphere {<0,0,0>, 100 pigment {rgbf <1, 1, 0, 0.9>} }
// "x axis" grid
#declare Loop = -18;
#while (Loop <= 18 )
	intersection {
		difference {
			sphere {<0,0,0>, Radius }
				sphere {<0,0,0>, Radius-Thickness }
		box { <-Thickness/2, -300, -200>, <Thickness/2, 0, 200> rotate
z*Loop*Step translate y*Radius }
		pigment {rgbf <0, 0, 1, 1>}
	#declare Loop = Loop + 1;
// "z axis" grid
	intersection {
		difference {
		box { <-200, -300, -Thickness/2>, <200, 0, Thickness/2> rotate
x*Loop*Step translate y*Radius }
		pigment {rgbf <1, 0, 0, 1>}
// Lines and transparent square
#declare Color1 = rgb <0, 1, 0>;
#declare Corner1 = 0;  // z
#declare Corner2 = 15;  // x  (+ = toward camera, - = away)
// boxes for comparison
union {
	box { <-Thickness/2, -Radius*3, -Radius>, <Thickness/2, Radius*3,
Radius> rotate z* Corner1   *Step translate y*Radius }
Radius> rotate z*(Corner1+1)*Step translate y*Radius }
	//box { <-Radius*2, -Radius*3, -Thickness/2>, <Radius*2, Radius*3,
Thickness/2> rotate x* Corner2   *Step translate y*Radius }
Thickness/2> rotate x*(Corner2+1)*Step translate y*Radius }
	pigment {rgbf <0.9, 0.9, 0.9, 1>}
cylinder { <0, 0, 0>, <0, -Radius*2, 0>, Thickness/2 rotate z*
Corner1*Step    rotate x* Corner2   *Step translate y*Radius texture
{pigment {Color1} finish {ambient 0.7} } no_shadow}
z*(Corner1+1)*Step rotate x* Corner2   *Step translate y*Radius texture
Corner1*Step    rotate x*(Corner2+1)*Step translate y*Radius texture
z*(Corner1+1)*Step rotate x*(Corner2+1)*Step translate y*Radius texture
difference {
		box { <-Radius*2, -Radius*3, -Radius*2>, <-Thickness/2, Radius*3,
Radius*2> rotate z* Corner1   *Step translate y*Radius }
		box { < Radius*2, -Radius*3, -Radius*2>, < Thickness/2, Radius*3,
Radius*2> rotate z*(Corner1+1)*Step translate y*Radius }
		box { <-Radius*2, -Radius*3,  Radius*2>, <Radius*2, Radius*3,
		box { <-Radius*2, -Radius*3, -Radius*2>, <Radius*2, Radius*3,
-Thickness/2> rotate x*(Corner2+1)*Step translate y*Radius }
		pigment {Color1 filter 1}
} // end WIP
// Plot objects
object {WIP translate <0, Height, -150> }
Subject: Re: Losing my mind
Date: 2 Apr 2014 18:15:00
Message: <web.533c8b06f07ab8a2f040ad170@news.povray.org>
> I dunno.
No need to lose your mind :)
I didn't try to debug your code, but I do have an alternate solution: use
trace() to project the plane's grid points onto the globe.
// ------- code -------
plane{y, 0 pigment{rgb .5}}
#declare SP = <0, 7, 0>; // sphere position
#declare SS = 4; // sphere size
#declare NP = SP + y*SS; // north pole
#declare TO = sphere{SP, SS}; // globe for rendering and trace()ing
object{TO pigment{rgb .5}}
sphere{NP, .2 pigment{rgb <1, 1, .1>}}
union{
 #local GS = 20;
 #for(Z, 0, GS-1)
  #for(X, 0, GS-1)
   #declare GP = <X, 0, Z>; // grid point
   #declare GP = GP - (x+z)*(GS-1)/2; // center the grid
   #declare TP = trace(TO, GP, NP-GP); // trace point
   sphere{GP, .2} // grid spheres on the plane
   sphere{TP, .1} // grid spheres on the globe
// ------- ~code -------
Hopefully that example is basic enough to make a good starting point, should you
go that route.
Sam
Date: 2 Apr 2014 18:25:00
Message: <web.533c8d37f07ab8a2f040ad170@news.povray.org>
// this code is better (the last version had size/alignment issues)
union{
 #local GS = 20;
 #for(Z, 0, GS)
  #for(X, 0, GS)
   #declare GP = GP - (x+z)*GS/2; // center the grid
Date: 2 Apr 2014 19:01:08
Message: <533c96b4$1@news.povray.org>
Thanks Sam,
Yes, I actually had thought to use Trace() to do what you're suggesting,
but  I was concerned that if I "cheated" and did that, I wouldn't
understand what I wasn't getting right with the simple task of aligning
CSG primitives.
And I'd like to eventually know what my major malfunction is before I
forge ahead and repeatedly run into the same problem again.
I will however give your trace codes a look, as I'm interested in doing
other projects where that would be a prime way to radiate out through a
grid intersection.
Date: 3 Apr 2014 12:50:01
Message: <web.533d90bdf07ab8a2c03071cc0@news.povray.org>
> Thanks Sam,
> CSG primitives.
> grid intersection.
In your first post you said that you rendered only parts of the scene. How far
did you take that?
Try this: make a new scene and rewrite your projection/transformation code.
Leave out the #while loops, extraneous geometry, commented code, etc., and focus
on projecting just /one/ single point, testing it for accuracy. Strip it all
down to the barest minimum and work from there.
If you're still having problems even after that, then post that new
stripped-down version here and I will try to help you. It's much easier for us
to help out when the code is as simple as possible :)
Sam
