POV-Ray : Newsgroups : povray.newusers : Good ways to keep curly braces straight Server Time
14 Sep 2025 16:26:57 EDT (-0400)
  Good ways to keep curly braces straight (Message 1 to 7 of 7)
Subject: Good ways to keep curly braces straight
Date: 10 Mar 2014 15:41:46
Message: <531e157a$1@news.povray.org>
... and the subject was intended to read just like THAT!   :D
Anyway,
I have a small (~500 line) file that I keep having issues with after
editing, where I either have an extra, or a missing curly brace.
I'd like some tips and tricks on organizing and visually keeping track
of my SDL code, and maybe even some clever thingsd embedded in the code
to help locate where the offending error resides.
Subject: Re: Good ways to keep curly braces straight
Date: 10 Mar 2014 16:33:49
Message: <531e21ad$1@news.povray.org>
Le 10/03/2014 20:42, Bald Eagle nous fit lire :
> Anyway,
what editor are you using ?
Some have the capability to:
 1. find the matching braces
 2. indent the code according to braces
For instance, with vi/vim/gvim, one basic trick is: all opening &
closing curly are alone on their own line. Indenting is just a matter of
moving to one curly brace and press =% (just two keys: = then % )
and everything inside the block get indented (to the amount of sw, so
':set sw=2' for an indent of 2 spaces)
Date: 10 Mar 2014 19:35:41
Message: <531e4c4d$1@news.povray.org>
Unfortunately, I'm running it on Winbloze, and so am using the internal
POV-Ray text editor.  I DL'd a text app for Win 8.1 that highlights
brackets and parentheses, but haven't tried to get pov-ray to run on
that OS yet...
I guess as soon as I get over this cold, I'll just try to pick through
it all and establish a logical and consistent indentation methodology.
Date: 10 Mar 2014 21:11:23
Message: <531e62bb$1@news.povray.org>
> that OS yet...
There's a "Kate" version for Windows available. It has everything you want for code
editing. It can handle Povray SDL as well. (Highlighting, brace checking etc).
Ger
Date: 10 Mar 2014 23:00:59
Message: <531e7c6b@news.povray.org>
> Anyway,
Assuming that you are using the Windows version.
With the cursor on a brace, you can use Ctrl+] to find the matching brace.
On the menu, under the "Text" heading, sellect:
Auto-Indent style -> Language scope
Now, if you start a new line after a brace, it will be idented.
After you close a brace, the next line identation will get reduced. When
you find yourself with no identation, it mean that all braces are matched.
This will also tend to make your code more readable.
Date: 11 Mar 2014 03:08:54
Message: <531eb686@news.povray.org>
On 03/10/2014 04:35 PM, Bald Eagle wrote:
> Unfortunately, I'm running it on Winbloze, and so am using the internal POV-Ray text
editor.  I
> DL'd a text app for Win 8.1 that highlights brackets and parentheses, but haven't
tried to get
> pov-ray to run on that OS yet...
> I guess as soon as I get over this cold, I'll just try to pick through it all and
establish a
You might try the free notepad++.  One of its capabilities is to show/hide blocks of
code, you
can sometimes find mismatched braces this way.  I'm sure there are other editors with
this
capability as well, but I do know notepad++ will do it.  I expect it will run on
Windows 8, but
don't know for sure.
<aside>
I'm a Linux guy, and have no interest in changing my Windows 7 installation to 8.  I
stick to
Linux (Mint) and rarely run Windows.  Actually, my preferred Windows editor is notetab
-- notice
that is noteTAB not notePAD.  But notepad++ is also an excellent programmer's editor
-- and free
as well.
</aside>
      -=- Larry -=-
Date: 11 Mar 2014 13:10:00
Message: <web.531f423cc3f8948a85de7b680@news.povray.org>
> Anyway,
Should you go the Kate route, a syntax highlighting file is located at
   http://news.povray.org/4f4092fb%40news.povray.org
so you don't have to download the Unix version of POV-Ray.  Kate highlights not
only curly braces, but square brackets and (most helpful to me) parentheses.
One thing I do that requires no software is that I use a non-customary formating
style.  Customarily, the opening brace is placed on the same line as the
keyword, for example:
   object {
      MyObject
      translate MyLocation
This confuses me to no end.  I prefer:
   object
   {  MyObject
This helps me keep better track of the braces and the blocks they enclose.  I
once read in a C/C++ style guide that thou shalt use the One True Brace Style.
Right.  If a brace style confuses me, it defeats its own purpose.
