POV-Ray : Newsgroups : povray.newusers : need help with parametric surface Server Time
10 Oct 2025 17:03:43 EDT (-0400)
  need help with parametric surface (Message 1 to 10 of 16)
Subject: need help with parametric surface
Date: 10 Mar 2014 11:31:20
Message: <531ddac8$1@news.povray.org>
hi,
newbie, first post.
having installed v 3.6.1 and played with it for a few days, I decided
that Ferguson's Umbilic Torus [1] would make a fine, first project.
alas, my lack of (mathematical) ability gets in the way of progress. :-(
using the scene file below, I get nothing but a black image.  I
interpret this output
  Ray->Shape Intersection          Tests       Succeeded  Percentage
  Parametric                      788225               0      0.00
  Parametric Bound                788225          788225    100.00
to mean that while the rays hit the default bounding box, they do not
hit the object that's meant to be inside [2].
I've tried various scales for the object and am now out of ideas.
---------- <snip> ----------
// umbilic.pov
// Helaman Ferguson's Umbilic Torus
#version 3.6;
  location <0,2,-5>
light_source {
  <0,5,0>
  color White
// equations from 3dps2v.tk
#declare oUmbilic = parametric {
  function {
sin(pi*u)*(7.0+cos((pi*u/3.0)-(2.0*pi*v))+2.0*cos((pi*u/3.0)+(pi*v))) },
  function {
cos(pi*u)*(7.0+cos((pi*u/3.0)-(2.0*pi*v))+2.0*cos((pi*u/3.0)+(pi*v))) },
  function { sin((pi*u/3.0)-(2.0*pi*v))+2.0*sin((pi*u/3.0)+(pi*v)) }
  <-1.0, -1.0>, <1.0, 1.0>
  contained_by { box { -1.1, 1.1 } }
//  accuracy .0001
object {
  oUmbilic
//  texture { uv_mapping pigment { Aquamarine } }
  pigment { rgb 1 }
any help appreciated.
[1] en.wikipedia.org/wiki/Umbilic_torus
    en.wikipedia.org/wiki/Helaman_Ferguson
[2] I got the x,y,z functions from Blaise Montandon's neat "3D Examiner
for Parametric Surfaces" program which can be found at wiki.tcl.tk/37524.
Subject: Re: need help with parametric surface
Date: 10 Mar 2014 12:13:38
Message: <531de4b2$1@news.povray.org>
I changed the following code and get *something* visible, not sure it's
what you want though:
> camera {
>    location <0,2,-5>
      look_at <0,-4,0>
>    contained_by { box { -10, 10 } }
Date: 10 Mar 2014 13:35:05
Message: <531df7c9$1@news.povray.org>
hi scott,
thank you for the swift (~45mins!! wow) reply.
On 10/03/2014 16:13, scott wrote:
> .. *something* visible ..
I see what you mean :-)
>> camera {
>>    location <0,2,-5>
>      look_at <0,-4,0>
well it gives me something to start from.  I now suspect that the object
isn't located at origin and/or that the camera may be somewhere inside
it (because the "*something*" looks like a small section of the object).
I'll play with it tonight.  thanks again.
Date: 10 Mar 2014 22:49:56
Message: <531e79d4@news.povray.org>
> hi scott,
>>> camera {
>>>     location <0,2,-5>
>>       look_at <0,-4,0>
Looking at your function, I suspect that the object is certainly
contained in a box much larger than the original containing box. My bet
would be: box {<-9, -2, -9>, <9, 2, 9>}
Make it larger if the object is clipped.
Add an identical box with pigment{rgbt<1, 0.1, 0.1, 1>} to your scene if
it looks like there are missing parts.
You can also add inside_texture{pigment{rgb<1,0,0>}finish{ambient 1}}.
That way, any hole should appear in bright red.
Next, the camera needs to be located outside that box.
It can be achieved by placing the camera accordingly, or translating the
object itself.
Date: 11 Mar 2014 16:48:55
Message: <531f76b7@news.povray.org>
hi Alain,
thank you for replying.
On 11/03/2014 02:50, Alain wrote:
> Looking at your function, I suspect ... box {<-9, -2, -9>, <9, 2, 9>}
I followed your advice and used those bounds, initially with colour to
verify the camera placing.  I also placed the box with the transparency.
no joy though, still all black; I even managed to lose the "*something*"
found by Scott. :-(
after some more googling I downloaded Ingo's MMGM and had a look at his
p_umbilic.pov file, which works nicely (and so much faster than the
parametric).  what is very confusing though is that Ingo's version swaps
the x and z functions when compared to the formulas in Wikipedia and
Blaise Montandon's program, and also that BM's formulae incorporate the
pi and use -1..1 bounds while the others use -pi..pi bounds, a different
way of scaling I assume?
I shall have to burn some more 'midnight oil', my aim is to use the
parametric because, AIUI, the surface can then be decorated with a
texture which itself is the result of a computation (needed, I think, to
replicate the Hilbert curve engraved on the original artwork).
btw, inside_texture is not available in v3.6.
Date: 11 Mar 2014 18:12:23
Message: <531f8a47@news.povray.org>
> found by Scott. :-(
The <-pi,pi> bounds are the values used for the computations. As if you
compute the cosinus in the range <-pi,pi> or in the range <-1,1>, it is
not a way to scale. Ex, the values for a circle are in the range
<0,2pi>, which is like <-pi,pi>.
I think Alain make an syntax error, he probably thought:
interior_texture{pigment{rgb<1,0,0>}finish{ambient 1}}
And why not install PovRay 3.7?
If your image is desperately black, add the background statement in your
scene:
    background {color rgb <0.2,0.4,0.75>}
I can't understand what you want, the p_umbilic.pov file make exactly
what you want. I think (but I am human and I could be wrong) you can
texture this object like another, you create your texture with
calculations and apply then to the shape.
I hope you succeed in your image.
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
Date: 12 Mar 2014 19:19:39
Message: <5320eb8b$1@news.povray.org>
hi Lionel,
thanks.  as I said, my maths is .. poor.
ok.
I'm very new to using Povray and v3.6 will be fine for 'learning the ropes'.
it does, but first I want to learn how to do certain objects/scenes
rather than using a pre-made solution (though it's always good to have a
fall-back).
you, for example, have already enough knowledge to see that Alain just
made a simple error.  I will need to work/learn to gain understanding,
so that I too could spot such errors.
texturing is some way off yet, but I'll bear in mind that both methods
are available.
sincere thanks.
Date: 12 Mar 2014 20:18:49
Message: <5320f969@news.povray.org>
> hi Alain,
> found by Scott. :-(
Oups! It's should have been interior_texture, and it's definitively a
feature found in 3.6. Not sure, but it may have been there in 3.5 or
earlier.
You should upgrade to version 3.7. It's somewhat faster, can take
advantage of all cores on modern computer, have several bug fixes,
introduce some new features like subsurface light transport and high
dynamic range images as source and output option.
It also have some improvements for focal blur and antialiasing. The irid
code is totaly redone as it was broken in version 3.6: Just add this to
some finish to see what's the problem (also try with turbulence 10, 1,
0.1, 0.01):
irid{0.2 thickness 0.2 turbulence 0.001}
Date: 12 Mar 2014 20:21:16
Message: <5320f9fc@news.povray.org>
> hi Lionel,
> ok.
You should go straight to version 3.7. That way, you won't need to
UNlearn some of those "ropes"...
Date: 13 Mar 2014 07:40:16
Message: <53219920@news.povray.org>
Hi Jr,
I have modified Ingo's file like this:
#declare Set=5;
// in switch block add:
#case (5)
#declare F1= function(u,v)
{sin(pi*u)*(7.0+cos((pi*u/3.0)-(2.0*pi*v))+2.0*cos((pi*u/3.0)+(pi*v))) };
#declare F2= function(u,v)
{cos(pi*u)*(7.0+cos((pi*u/3.0)-(2.0*pi*v))+2.0*cos((pi*u/3.0)+(pi*v))) };
#declare F3= function(u,v) {
sin((pi*u/3.0)-(2.0*pi*v))+2.0*sin((pi*u/3.0)+(pi*v)) };
#break
// in object block add:
#if (Set=5)
Parametric(
	F1, F2, F3,
	<-pi, -pi>, < pi, pi>,
	50,50,""
I remark your object have some holes on the borders, maybe you have to
modify the formulas.
Lionel.
parce que la protection avast! Antivirus est active.
