POV-Ray : Newsgroups : povray.newusers : need help with parametric surface Server Time
28 Sep 2024 06:21:00 EDT (-0400)
  need help with parametric surface (Message 11 to 16 of 16)
Subject: Re: need help with parametric surface
Date: 13 Mar 2014 07:43:01
Message: <532199c5$1@news.povray.org>
Me again,
just little changes in the formulas, I delete all pi and the torus is
better.
#declare F1= function(u,v)
{sin(u)*(7.0+cos((u/3.0)-(2.0*v))+2.0*cos((u/3.0)+(v))) };
#declare F2= function(u,v)
{cos(u)*(7.0+cos((u/3.0)-(2.0*v))+2.0*cos((u/3.0)+(v))) };
#declare F3= function(u,v) { sin((u/3.0)-(2.0*v))+2.0*sin((u/3.0)+(v)) };
Lionel.
Do not judge my words, judge my actions.
parce que la protection avast! Antivirus est active.
http://www.avast.com
Date: 13 Mar 2014 19:45:05
Message: <53224301$1@news.povray.org>
hi Alain,
On 13/03/2014 00:21, Alain wrote:
> You should go straight to version 3.7. That way, you won't need to
> UNlearn some of those "ropes"...
hmm, are you saying that the syntax for /existing/ SDL statements has
changed from 3.6 to 3.7?
> It's somewhat faster, can take advantage of all cores on modern
> computer, have several bug fixes, introduce some new features like
> subsurface light transport and high dynamic range images as source
> and output option.
> It also have some improvements for focal blur and antialiasing.
> The irid code is totaly redone as it was broken in version 3.6 ...
I might (for now) miss out on bug fixes and new features, but that's ok
for a learner; wrt multiple cores - I run Povray on a VM which is
limited to 'see' 1 cpu and 1G RAM.
Date: 13 Mar 2014 19:48:20
Message: <532243c4$1@news.povray.org>
hi Lionel,
On 13/03/2014 11:46, FractRacer wrote:
> I have modified Ingo's file like this:
> better.
merci bien, Lionel.  I'll probably keep that file modification.
Date: 15 Mar 2014 16:16:15
Message: <5324b50f$1@news.povray.org>
> hi Alain,
Some feature work in a slightly different way.
Some features have some alternative or optional syntax, like back side
illumination that is invoked be using 2 parameters for the diffuse value.
There are some bug fixes.
There are several workarounds that are no longer needed, of may actualy
cause some problems.
There are HUGE changes with radiosity.
Focal blur have been revamped and now work along with regular
antialiasing. It's also significatively faster.
The paremeters for irid work differently: They are now more closely
related to actual physical properties.
If you try to render some newer scenes that use new features that you
can find on the forums, it may abort with some error if you are still
using version 3.6.
>> and output option.
Version 3.6 NOT OK for a learner :( At least, it's no longer OK.
The learning curve is the same for both versions. Even if your VM
environment only expose a single CPU/core, there is no reason to stick
with version 3.6. Version 3.7 is the current OFFICIAL release.
Date: 15 Mar 2014 16:24:40
Message: <5324b708$1@news.povray.org>
>> hi Alain,
> using version 3.6.
>>> and output option.
> Alain
By the way, my antiquated computer have only a single CPU, and after I
upgraded to version 3.7 there is NO idea of ever turning back. It works
SO much beter!
Date: 17 Mar 2014 18:54:20
Message: <53277d1c$1@news.povray.org>
hi Lionel and Alain,
to follow up, the scene below uses the parametric directly.
Alain's bounding box guess was pretty close (I've added a
frame to show it), I had expected a much smaller object.
----------<snip>----------
// umbilic torus
#version 3.6;
#include "shapes.inc"
light_source { <100,100,-100> color White }
  location <0,0,-30>
  look_at <1,-1,0>
#declare oUmbilic = parametric {
  function {sin(u)*(7+cos((u/3)-(2*v))+2*cos((u/3)+v))},
  function {cos(u)*(7+cos((u/3)-(2*v))+2*cos((u/3)+v))},
  function {sin((u/3)-(2*v))+2*sin((u/3)+v)}
  <0,0>,<2*pi,2*pi>
  contained_by { box { <-10,-10,-3>, <10,10,3> } }
  accuracy .0001
  precompute 15 x,y,z
union {
  object { oUmbilic pigment { Blue } }
  object {
    Wire_Box_Union(<-10.1,-10.1,-3.1>,<10.1,10.1,3.1>,.05)
    pigment { Red }
  rotate -z*15
  rotate x*30
  rotate y*clock*360
thank you both.
