POV-Ray : Newsgroups : povray.newusers : Transparent object casting a shadow with radiosity Server Time
26 Mar 2026 02:58:12 EDT (-0400)
  Transparent object casting a shadow with radiosity (Message 1 to 5 of 5)
Subject: Transparent object casting a shadow with radiosity
Date: 9 Oct 2013 22:07:32
Message: <52560be4@news.povray.org>
I'm sure I'm missing something obvious here, but I can't seem to figure
out what it is.  I'm trying to render a scene using HDR lighting from a
light probe, and am finding that semi (or even wholly) transparent
objects are interacting with radiosity as if they were opaque.  I've
tried cranking up max_trace_level and recursion_limit to no effect.
I've included a sample scene which shows the problem.  The scene
contains a bright disc as a radiosity-based light source, a white plane,
and a transparent disc slightly over the plane.  Despite the fact that
the disc is completely transparent, it seems to be casting a shadow and
a get this result: http://i.imgur.com/PME9OfO.png  I get similar results
for partially-transparent objects where their shadows are much darker
then they should be.
Anyone know what I'm doing wrong?  I'm using Povray version
3.7.RC7.msvc.win64.
#version 3.7;
global_settings {
   assumed_gamma 2.2
   max_trace_level 10
   ambient_light rgb 1
   radiosity {
     // as far as I know, these should be really high-quality settings
     pretrace_start 0.08
     pretrace_end   0.004
     count 2000
     nearest_count 9
     error_bound 0.2
     recursion_limit 10
     low_error_factor 0.2
     gray_threshold 0
     minimum_reuse 0.01
     brightness 1.0
     adc_bailout 0.01/2
   orthographic
   location <0, 0, 10>
   direction <0, 0, -1>
   right 2*x
   up 2*y
background {
   color rgb 0
// set up a `light source' to cast shadows via radiosity
disc {
   2*z, z, 1.0, 0.0
   pigment{ color rgb 1 }
   finish { diffuse 0 emission 5 }
   hollow
   no_image
   no_shadow
   scale 10000
// a plane for the shadows to be cast upon
plane {
   z, 0
   pigment { color rgb 1 }
   finish { ambient 0 diffuse 1.0 }
// This disc is completely transparent, so why does it cast a shadow?
disc {
   0.1*z, z, 0.9, 0.5
   pigment { color rgbt 1 }
   finish { diffuse 1 }
Subject: Re: Transparent object casting a shadow with radiosity
Date: 10 Oct 2013 15:53:53
Message: <525705d1$1@news.povray.org>
> 3.7.RC7.msvc.win64.
> #version 3.7;
> global_settings {
>    assumed_gamma 2.2
>    max_trace_level 10
>    ambient_light rgb 1
>    radiosity {
>      pretrace_start 0.08
>      pretrace_end   0.004
>      count 2000
>      nearest_count 9
>      error_bound 0.2
>      recursion_limit 10
>      gray_threshold 0
>      minimum_reuse 0.01
>      brightness 1.0
>      adc_bailout 0.01/2
> camera {
>    orthographic
>    location <0, 0, 10>
>    right 2*x
>    up 2*y
> background {
>    color rgb 0
> disc {
>    2*z, z, 1.0, 0.0
>    hollow
>    no_image
>    no_shadow
>    scale 10000
> plane {
>    z, 0
> disc {
>    0.1*z, z, 0.9, 0.5
Remove the no_image from the light source disk. I posted about this
issue too but got no replies so I suppose it is the expected behavior.
here is my post:
http://news.povray.org/povray.general/thread/%3C519adfbf%241%40news.povray.org%3E/?ttop=387306&toff=50
FlyerX
Date: 10 Oct 2013 20:48:22
Message: <52574ad6$1@news.povray.org>
Thanks, that fixed it!
I rather hope that's not the expected behavior, as it's quite
counterintuitive and I'd imagine pretty annoying when you want to use
+UA on a scene lit by objects of this sort.
I'm glad to have a fix for my purposes though.
> here is my post:
> FlyerX
Date: 11 Oct 2013 12:42:15
Message: <52582a67@news.povray.org>
>> here is my post:
>> FlyerX
Normaly, you don't need the no_image on emissive objects. Also,
no_shadow is usualy not needed.
Date: 9 Nov 2013 11:32:42
Message: <527e63aa$1@news.povray.org>
Am 11.10.2013 02:48, schrieb Kevin Wampler:
It's counterintuitive to me as well, so no - that behaviour is /not/
expected, and I'll look into the problem.
Sorry I hadn't picked up the earlier thread by FlyerX (and haven't
replied to this one earlier as well), but there are times when I don't
find time to keep up with the newsgroups postings.
If you find such issues but don't get a response, please submit a bug
report on http://bugs.povray.org; whatever ends up in there doesn't get
lost, even if it doesn't prompt an immediate reaction.
Until I get back with a fix, can you please verify that this problem is
also present in the official 3.7.0 release?
