POV-Ray : Newsgroups : povray.newusers : Re: Using vector components as function parameters Server Time
15 Jul 2026 06:28:03 EDT (-0400)
  Re: Using vector components as function parameters (Message 1 to 3 of 3)
Subject: Re: Using vector components as function parameters
Date: 20 May 2013 12:19:56
Message: <519a4d2c$1@news.povray.org>
>> How come this doesn't parse:
>> #local V = <0,1,2>;
>> #local f = function(x,y,z){ sin(x*V.x) }
>> but this does:
>> #local V = <0,1,2>;
>> #local Vx = V.x;
>> #local f = function(x,y,z){ sin(x*Vx) }
> Vectors don't work in functions. Nothing vector-like will work, except if your
> function is a special vector function (defined as a transform or a spline).
> Everything else is scalar-only.
Isn't V.x a scalar value? It's not obvious why it results in an error,
after all the parser internally should evaluate V.x and Vx to exactly
the same value (zero in this case).
> This message is better suited for the "newusers" section.
Oops, must have selected the wrong group... changed it now.
Date: 21 May 2013 20:18:59
Message: <519c0ef3@news.povray.org>
AFAIK the function parser is different from the normal parser,
and therefore more restricted.
Date: 22 May 2013 03:12:33
Message: <519c6fe1$1@news.povray.org>
OK that explains it then.
