POV-Ray : Newsgroups : povray.newusers : --- Server Time
16 Dec 2025 03:35:16 EST (-0500)
  --- (Message 1 to 2 of 2)
Subject: Re: Wrapping paper question
Date: 12 Dec 2009 22:05:38
Message: <4b245a02$1@news.povray.org>
> Hi all,
> I've been a POVRay user for years but haven't touched it much in the last 8
> months. I'm coming back to it and am a little rusty.
> I've decided to do an XMas scene and want to add some wrapped presents. I
> have a number of images which tile to make different wrapping paper
> patterns.
> I'm having an issue getting the wrapping paper to map to the gifts (simple
> boxes at the moment) - I obviously want the pattern to be visible without
> distortion on each surface of the box.
> From the manual, I've had a look at the map_types but they don't seem to
> solve my problem. At the moment, the only solution I can see is to use 6
> "flat" boxes to make up the different sides and try to make the patterns
> meet up correctly.
> Curent code is simply:
>    #local GiftTexture = texture {
>     pigment {
>      image_map {jpeg Filename}
>      scale .25
>     finish {
>      ambient 0 diffuse 1
> box{<blah>
>     texture{GiftTexture}
> I've (hopefully) attached a link to a post with some images. in case I've
> messed up, the post is in p.b.i titled "Images for a question in advanced
> users re: wrapping paper"
> Can someone please either tell me how I can achieve this or point me at the
> right method?
> Many thanks in advance
> Simon
The image_map is effectively an infinite volume having your image in a
given direction.
Any object is "carved" from that, it don't wrap around.
Some things you can do:
Use a mesh and UV map your image.
Construct your box from smaller, thin, boxes. Create them all with a
common surface and connected, as if from a single surface. You then
rotate the various parts as needed to create your final box. Start by
the most outside ones, bind in an union and rotate the next one. By
using triangular and trapezoidal elements, you can recreate the way
actual wraping paper overlap on real boxes.
Date: 13 Dec 2009 01:38:44
Message: <4b248bf4@news.povray.org>
> common surface and connected, as if from a single surface. You then rotate
> the various parts as needed to create your final box. Start by the most
> outside ones, bind in an union and rotate the next one. By using
> triangular and trapezoidal elements, you can recreate the way actual
That's a fantastic suggestion - I'll give it a go, many thanks
Simon
