POV-Ray : Newsgroups : povray.newusers : Bumps, squared. Server Time
16 Aug 2025 21:13:51 EDT (-0400)
  Bumps, squared. (Message 1 to 6 of 6)
Subject: Bumps, squared.
Date: 8 Dec 2007 22:02:56
Message: <475b5ae0@news.povray.org>
I was trying to do some isosurface-like things with some functions.  I
wanted a pigment pattern which was based on the values generated by bumps
(or wrinkles, etc)  squared.
I found that I could not get any syntax that would work for declaring a
function from a pattern and then doing arithmetic operations on it, and
then using THAT as a pigment pattern.
Help is appreciated, thanks.
Subject: Re: Bumps, squared.
Date: 9 Dec 2007 02:35:01
Message: <web.475b9966fb428a64a3740fdb0@news.povray.org>
Hi Greg,
how about
#declare BumpFunc = function{ pattern{ bumps } };
#declare BumpSquared = function{ pow( BumpFunc( x, y, z ), 2 ) };
I didn't actually USE this for anything, but it seems syntactically correct
because POV-Ray doesn't choke on it - except for complaining about no objects
in scene ...
Greetings
Karl
Date: 9 Dec 2007 08:45:01
Message: <web.475bf04ffb428a644ae996d80@news.povray.org>
..... and now, after spending some time with my family on this beautiful sunday,
a
more complete example that really renders a picture, though WHAT that might be,
I really don't want to guess :-) ...
// cut HERE for BumpFunc.pov
#declare BumpFunc = function{ pattern{ bumps} };
it's interesting that that is FASTER than
#declare BumpSquared = function{ BumpFunc( x, y, z )*BumpFunc( x, y, z ) };
isosurface {
 function {
  0.5-BumpSquared( x, y, z )
 max_gradient 1.35
 contained_by {
  sphere { <0.0, 0.0, 0.0>, 8 }
 rotate y*90
 scale 0.25
 #declare COLORS = yes;
 #if( COLORS )
   spherical
   color_map {
    [ 0.00000 rgb < 1.00000, 0.50000, 1.00000> ]
    [ 0.10000 rgb < 1.00000, 0.50000, 1.00000> ]
    [ 0.21400 rgb < 0.50000, 0.50000, 1.00000> ]
    [ 0.32800 rgb < 0.20000, 0.20000, 1.00000> ]
    [ 0.44200 rgb < 0.20000, 1.00000, 1.00000> ]
    [ 0.55600 rgb < 0.20000, 1.00000, 0.20000> ]
    [ 0.67000 rgb < 1.00000, 1.00000, 0.20000> ]
    [ 0.78400 rgb < 1.00000, 0.50000, 0.20000> ]
    [ 0.90000 rgb < 1.00000, 0.20000, 0.20000> ]
    [ 1.00000 rgb < 1.00000, 0.20000, 0.20000> ]
   scale 2
 #else
  pigment{ color rgb 1 }
 #end // #if( COLORS )
light_source {
 -10*z+y
 rgb 0.5
light_source {
 -10*z+y-2*x
 rgb 0.5
light_source {
 -10*z+y+2*x
 rgb 0.5
 location < 0.0, 0.0, -5>
// cut HERE again for end of BumpFunc.pov
Enjoy
Karl
Date: 9 Dec 2007 09:10:00
Message: <web.475bf638fb428a6434d207310@news.povray.org>
> on this beautiful sunday, a more complete example that
Okay, great thanks.  I couldn't test your first reply as my PC is in a day-long
render right now. :-S
I think the key help you provided was in the word "pattern". thanks.
Date: 9 Dec 2007 09:50:00
Message: <web.475c0030fb428a642ae8612c0@news.povray.org>
Try using the poly_wave waveform modifier.  (I think poly_wave 2 is the one you
want or poly_wave 0.5)
-tgq
Date: 9 Dec 2007 20:50:01
Message: <web.475c9ab7fb428a642ae8612c0@news.povray.org>
> -tgq
Actually, now that I thought about it, I don't think this is what you were
looking for, it affects the mapping, not the colour.  You can manipulate
pigment through colours, but keep in mind that functions don't carry vectors.
Try something like this:
#declare MyPig=pigment{bozo}  //your  priginal pigment
#declare PFunk=function{pigment{MyPig}}//declare it as a function
#declare FRd=function{PFunk(x,y,z).red  }//separate the red, green and blue
components
#declare FGn=function{PFunk(x,y,z).green}
#declare FBl=function{PFunk(x,y,z).blue }
#declare FRed=function{FRd(x,y,z)} //manipulate these functions how you want
#declare FGrn=function{FGn(x,y,z)}
#declare FBlu=function{FBl(x,y,z)}
#declare MyPig2=
pigment{average//average pigment to reassemble RGB components
  pigment_map{
      [function{FRed(x,y,z)} color_map{[0 rgb 0][1 rgb <3,0,0>]}]
      [function{FGrn(x,y,z)} color_map{[0 rgb 0][1 rgb <0,3,0>]}]
      [function{FBlu(x,y,z)} color_map{[0 rgb 0][1 rgb <0,0,3>]}]
-tgq
