POV-Ray : Newsgroups : povray.newusers : optic guide. Server Time
13 Mar 2026 22:13:30 EDT (-0400)
  optic guide. (Message 11 to 14 of 14)
Subject: Re: optic guide.
Date: 9 Jun 2007 23:01:42
Message: <466b6996$1@news.povray.org>
TP Electronics nous apporta ses lumieres en ce 2007/06/09 07:57:
> I want to desing a optic guide for en LED.
> It is possible to simulated this with povray?
> I can not see where I can change specification of material to define the
> guide.
> I am play with led source but not manage to make a led with 10degres angle.
> Best regard
> Thierry
My gues would be to use photons.
Add the folowing to your light guide deffinition:
photons{target refraction on reflection on collect off}
(this can be added in a material{...} block)
and the following to your #global_settings{...} block:
photons{count 100000} OR photons{spacing 0.01}
Photons are a form of "forward" tracing where you start from the light_source,
go toward selected objects marked with a target atribute, then to other object
or the camera.
A ray tracer normaly use backward ray tracing where you start from the camera to
the object and test with light_source to know the illumination.
My toes were playing the piano under the blankets.
They made so much noise that I woke up singing.
Date: 10 Jun 2007 03:08:45
Message: <466ba37d$1@news.povray.org>
Well it must be the rigth way but do not understand how to use it.
I do not find "clear" example. It is a picture to show what I want to do but
not example of code.
I have spend to much hours to try.
Thanks for all help.
Perhaps I will try later if I fnd more info.
I can not understand how to use photons and where?
"Alain" <ele### [at] netscapenet> skrev i melding
news:466b6996$1@news.povray.org...
>> guide.
>> angle.
>> Best regard
>> Thierry
> light_source, go toward selected objects marked with a target atribute,
> then to other object or the camera.
> camera to the object and test with light_source to know the illumination.
> Alain
Date: 10 Jun 2007 03:59:37
Message: <466baf69$1@news.povray.org>
466ba37d$1@news.povray.org...
> but not example of code.
maybe a  drawing by hand :-)
Marc
If you want an accurate simulation, POV ins not the good way.
But if you accept to fake it, there are solutions
If I understand you put a LED behind a transparent/filtering piece of
plastic.
Marc
Date: 10 Jun 2007 09:35:28
Message: <466bfe20$1@news.povray.org>
Yes it is correct.
The close I arrived. with following code:
global_settings {photons { count 20000 autostop 0 jitter .4  } }
camera {location <0, 0,-12.0> look_at 0 angle 30 }
#declare LED_RED=
light_source { <0, 0, 0> color Red    }
#declare  KNOPP=
difference
        cylinder {<0,2,0><0,10,0>,12/2 }
        cylinder {<0,0,0><0,2+1.35,0>,3/2 }
        texture{T_Glass1 } finish {ambient .01 diffuse .9}
background {Gray20}
union
 object { LED_RED translate<6.000000-4.25,00000,6.000000>}
 object { LED_RED translate<6.000000+4.25,00000,6.000000>}
 //cylinder {<0,2,0><0,10,0>,6 texture{T_Glass1 } finish {ambient .01
diffuse .5}
 object { KNOPP translate<6.000000,1.700000,6.000000>}
scale <.1,.1,.1>
rotate <30,0,0>
//End union
"Marc" <jac### [at] wanadoofr> skrev i melding
news:466baf69$1@news.povray.org...
> Marc
> plastic.
> Marc
Download 'photon.JPG' (10 KB)
Preview of image 'photon.JPG'
