POV-Ray : Newsgroups : povray.newusers : Transparent Objects Server Time
9 Jun 2026 01:05:00 EDT (-0400)
  Transparent Objects (Message 11 to 17 of 17)
Subject: Re: Transparent Objects
Date: 27 May 2007 12:16:44
Message: <4659aeec$1@news.povray.org>
Sorry, I should've been more clear - I'm actually just using a real sphere
with various lighting effecets to light my scene - so whilst it is
technically a sky sphere, it's not done the way POV usually would - I'm
trying to get a natural lighting effect (as per a seminar I saw by Paul
Debevec). Results have been quite good (I've posted a vid in p.b.a if you're
interested)
The Sky declaration is:
 union{
  sphere{0,5
   hollow no_shadow
   texture{
    pigment{
     function{fp(x,y,z).gray}
     poly_wave light_exponent
     color_map{
     [0.0 rgb 0]
     [1.0 rgb light_ambient]
  finish { ambient light_ambient diffuse 0 }
  sphere{0,4.999
   hollow no_shadow
   texture{
    pigment{p_image_filtered}
(I hasten to add that this is not my code - I grabbed it online. Am not 100%
sure where from but will find it if anyone wants to know)
Thanks for any help you can give Stephen :)
-Simon
"Stephen" <mcavoysATaolDOTcom@> wrote in message
news:5iaj539kp36u1urgbqo3th2pgbv7lf2u5a@4ax.com...
> On Sun, 27 May 2007 14:41:24 +0100, "Simon" <povray@*NOSPAM*SOWare.co.uk>
> wrote:
>>It's working (ish) with the objects. I have a sky sphere and want to fade
>>that too....
> I've never obtained satisfactory results when trying to fade an object. So
> I
> might not be the best person to help you further. :-(
> But I've just checked this and it looks like Pov can only use one
> sky_sphere.
> The last in the scene is the one it uses.
> Regards
> Stephen
Date: 27 May 2007 19:56:03
Message: <465a1a93$1@news.povray.org>
>  union{
>   sphere{0,5
>    hollow no_shadow
>    texture{
>     pigment{
>      color_map{
>      [0.0 rgb 0]
>   sphere{0,4.999
>    hollow no_shadow
>    texture{
Have the inner sphere become increasingly transparent to reveal the
outer sphere.
If p_image_filtered is a texture declared in Pov, you can add change the
transmit value of the colors as mentioned earlier in the thread.
If it's an image, you can use the transmit bitmap modifier, described here:
http://povray.org/documentation/view/3.6.1/337/
(While I was looking that up, I accidentally ran across the
interior_texture option. I didn't know about that--it looks really useful!)
William Tracy
|a|f|i|s|h|i|o|n|a|d|o|@|g|m|a|i|l|.|c|o|m|
|w|t|r|a|c|y|@|c|a|l|p|o|l|y|.|e|d|u|
You know you've been raytracing too long when you actually contemplate
spending $$$ at a printing bureau to litho some of your raytraces for
your non-computer-literate relatives.
George Erhard
Date: 28 May 2007 08:38:35
Message: <465acd4b@news.povray.org>
"William Tracy" <wtr### [at] calpolyedu> wrote in message
news:465a1a93$1@news.povray.org...
> here:
Thanks so much, that was exactly what I was looking for! Between you and
Stephen, I've got my answer. Thank you all so much!
Date: 28 May 2007 08:54:08
Message: <465ad0f0$1@news.povray.org>
news:46597085@news.povray.org...
>  A completely transparent interior_texture might be worth a try if you
> want to make the inner sides invisible.
Thanks for that Warp, I was getting a problem where: If the object passed
behind itself while transparent, It is visible even is the transparency
should be 100% - I think this may fix it...
Thanks again,
S
Date: 28 May 2007 09:08:47
Message: <465ad45f@news.povray.org>
  That may have more to do with max_trace_level.
Date: 28 May 2007 09:23:49
Message: <465ad7e5@news.povray.org>
(excuse me while I go kick myself a few times)
It may well do. I reduced max_trace so I could get some test renderings done
with positioning - and never set it back up before moving on. As I've never
used transparency before, I assumed I was making a mistake there.
Thanks Warp.
news:465ad45f@news.povray.org...
>                                                          - Warp
Date: 28 May 2007 16:36:37
Message: <465b3d55$1@news.povray.org>
I've certainly made max_trace_level mistakes myself.
I remember posting one image here with the comment that I might need to
go back and make some of the shapes slightly lighter and less opaque.
Someone pointed out that had nothing to do with it--it was
max_trace_level. :-P
William Tracy
You know you've been raytracing too long when you've tried rendering
hair with each strand as an object.
Quietly Watching
