POV-Ray : Newsgroups : povray.newusers : Paper Texture Server Time
29 Sep 2024 06:21:18 EDT (-0400)
  Paper Texture (Message 1 to 4 of 4)
Subject: Paper Texture
Date: 27 Feb 2007 10:26:36
Message: <45e44dac$1@news.povray.org>
I've been trying to develop a texture which resembles old
paper/parchment.  I've not yet got the effect I want - I can get a
texture that looks fine from a distance, but cannot get something which
has that fibrous look close-up.  I'm also having trouble matching the
tan/brown colour of old paper (maybe I need a color_map?).  The only
other "catch" is that I need something which'll render relatively fast,
as I'm going to be using this in a fairly long animation - i.e. I'm
trying to avoid functions and isosurfaces.
Here's what I've got so far - the pigment is white; just to highlight
the texture.  As you can see, I've got a long ways to go:
#declare T_Paper = texture {
   pigment { color rgb <1,1,1> }
   normal { wrinkles 1 scale 0.01 }
   finish { diffuse .7 roughness .0085 ambient 0.2 }
   }//end paper texture
Any ideas?
Bryan
Subject: Re: Paper Texture
Date: 27 Feb 2007 14:10:01
Message: <web.45e4811bf6158139977978930@news.povray.org>
I get the best results with paper textures by using an image_map and
bump_map together. You can find some good paper textures on Paul Bourke's
site, http://local.wasp.uwa.edu.au/~pbourke/texture_colour/paper/. Use the
original as your image_map and use another, the same original converted to
grayscale, as a bump_map. (You can use the same image for both but the
creases won't be so pronounced) Then use something like:
      image_map {
    finish {
      ambient 0.1
      diffuse 0.5
    normal {
      bump_map {
        bump_size 6         //reduce for wrinkles, increase for creases
        interpolate 2
It works best if you want heavy creases or folds.
Steve Klebs
http://www.cloudinthesky.com
Date: 28 Feb 2007 09:56:07
Message: <45e59807$1@news.povray.org>
> bump_map together.
Looks like that's the route I'm going to have to take.  My first
attempts with the bump maps and image maps looks far better then any of
my textures developed over the last 2 days.
Thanx for your help
Bryan
Date: 1 Mar 2007 12:50:01
Message: <web.45e7112ef61581391009749b0@news.povray.org>
> > bump_map together.
> Thanx for your help
> Bryan
Here's a procedural texture for a coarse grain paper (normals based on
leopard pattern):
#declare paper = texture {
  pigment { granite
    color_map {
     [0 color rgb <1,0.98,0.95>]
     [0.2 color rgb <1,0.98,0.95>]
     [0.21 color rgb <1,0.96,0.83>]
     [0.3 color rgb <1,0.96,0.83>]
     [0.4 0.5 color rgb <1,0.98,0.95> color rgb <1,0.98,0.95>]
     [0.51 0.6 color rgb <.77,0.54,0.33> color rgb <.77,0.54,0.33>]
     [0.61 0.9 color rgb <1,0.96,0.83> color rgb <1,0.96,0.83>]
     [0.91 color rgb <.77,0.54,0.33>]
     [1 color rgb <.77,0.54,0.33>]
  scale 0.5
texture { pigment { color rgbt <1,0.96,0.83,0.1>}
  normal { leopard 1 turbulence 1.7 scale 0.01 }
- Mike
