POV-Ray : Newsgroups : povray.newusers : Parsing Q Server Time
18 Aug 2025 22:05:14 EDT (-0400)
  Parsing Q (Message 1 to 8 of 8)
Subject: Parsing Q
Date: 28 May 2006 13:56:17
Message: <4479e441$1@news.povray.org>
I'm preparing to do a high quality render of an animation I've setup.
Because of the large size of the animation (15,800 frames, 720x480) I'm
looking for any way to improve rendering speed.  The animation is
divided into 22 "scenes", each one of which is regulated using if
statements.  I was wondering if the material between the #if and #end
portions of a scene are still parsed if the #if statement is false.  Or,
in other words, if it would be faster to delete or comment out portions
of the animation not being used in the current round of rendering.
Bryan
Subject: Re: Parsing Q
Date: 28 May 2006 14:12:44
Message: <4479e81c$1@news.povray.org>
news:4479e441$1@news.povray.org...
> Bryan
According to the documentation, the portion between #if and #end is skipped
if the condition is false
http://www.povray.org/documentation/view/3.6.1/241/
Marc
Date: 28 May 2006 15:31:03
Message: <4479fa77$1@news.povray.org>
As Marc already told you, there's no need to remove those sections. For
some more tips on speeding up POV-Ray renders check out the POV-Ray
speed guide:
	http://povray.tirnalong.com/ow.asp?p=SpeedGuide
HTH,
Florian
Date: 29 May 2006 04:28:58
Message: <447ab0c9@news.povray.org>
  *Interpreting* that part is skipped, but POV-Ray has to go through it
in order to find the proper #else or #end in the first place. It can't
magically know where it is located if it doesn't go through the tokens
in the scene.
  IOW it will parse the body of the #if (in order to find the #else or #end)
but it will not interpret it.
Date: 29 May 2006 07:15:45
Message: <447ad7e1$1@news.povray.org>
news:447ab0c9@news.povray.org...
#end)
It should be faster than real parsing isn't it?
Marc
Date: 29 May 2006 10:34:26
Message: <447b0672$1@news.povray.org>
Depends, I guess: Consider this scene:
	#if (0)
		#declare b = 0;
		#while (b<1000000)
			sphere { x*b, 0.5 pigment { rgb 1 } }
			#declare b = b + 1;
	#else
Parsing it takes 0 seconds (Because the loop is parsed, but not
executed). But if you replace the loop with actual data, like this:
	#if (0)
		sphere { x*0 0.5 pigment { rgb 1 } }
		sphere { x*1 0.5 pigment { rgb 1 } }
		sphere { x*2 0.5 pigment { rgb 1 } }
		sphere { x*999997 0.5 pigment { rgb 1 } }
		sphere { x*999998 0.5 pigment { rgb 1 } }
		sphere { x*999999 0.5 pigment { rgb 1 } }
	#else
Parsing takes 11 seconds, because this time each sphere has to be parsed
separately.
So if you're long parsing times are caused by lengthy calculations in
loops or recursion (but are short in terms of lines of SDL), then
removing them won't really shorten parse time. But if they are caused by
"real parsing", you're better off moving that data to an include file:
	#if (0)
		#include "test2.pov"
	#else
Takes 0 seconds to parse (test2.pov contains the 10000000 sphere
definitions from above).
HTH,
Florian
Date: 29 May 2006 10:44:04
Message: <447b08b4$1@news.povray.org>
> speed guide:
> HTH,
> Florian
Thanx everyone for the info.
Bryan
Date: 30 May 2006 14:40:49
Message: <447c91b1@news.povray.org>
  I think you are confusing terms here.
  Parsing a script means to split it (internally) into meaningful tokens.
Interpreting it, which you call "real parsing" is to act upon those tokens.
  POV-Ray has to parse the file in order to find the proper #end.
