POV-Ray : Newsgroups : povray.newusers : sum of 2 normals Server Time
17 May 2026 21:13:41 EDT (-0400)
  sum of 2 normals (Message 1 to 3 of 3)
Subject: sum of 2 normals
Date: 1 May 2006 12:10:11
Message: <445632e3$1@news.povray.org>
I'd like to blend 2 normals.
for example I do :
normal {brick}
normal {dents}
and I hope to have a mixture of both. It doesn't work. More, if I switch
both, I don't obtain the same result (!)
I switched with functions :
#declare n1=function{pattern{bumps}}
#declare n2=function{pattern{dents}}
#declare NORM=function{n1(x,y,z)+n2(x,y,z)}
object {myobject normal{NORM}}
and it doesn't work... More, if I switch n1 and n2 in the NORM function, I
don't obtain the same result.
I'm lost. What's wrong with my idea ?
Subject: Re: sum of 2 normals
Date: 1 May 2006 12:25:00
Message: <web.4456354134a3a00e6c4803960@news.povray.org>
> for example I do :
> normal {brick}
> normal {dents}
Read "2.3.4.2.2  Blending Normals" in the manual.  It states here that this
doesn't give the expected results.
To blend or add normals together, use the average function with normal_map.
-tgq
Date: 1 May 2006 12:27:54
Message: <4456370a$1@news.povray.org>
Thanks for your very fast answer.
I'm going to test it. (seems I've LOTS to learn about Pov...)
news:web.4456354134a3a00e6c4803960@news.povray.org...
> > for example I do :
> > normal {brick}
> > normal {dents}
this
normal_map.
> -tgq
