POV-Ray : Newsgroups : povray.newusers : textures and warp Server Time
29 Sep 2024 14:09:02 EDT (-0400)
  textures and warp (Message 1 to 4 of 4)
Subject: textures and warp
Date: 22 Apr 2006 04:39:55
Message: <4449ebdb$1@news.povray.org>
I cambe back on Pov after about 1 year stop and I have a texture problem.
Let's look at my example :
camera {location <0,0,-5> look_at 0}
light_source {<0,0,-5> color rgb 1}
#declare pig1=pigment {
        checker
        color rgb <1,0,0>
        color rgb <0,1,0>
        scale 0.3
#declare pig2=pigment {
        checker
        color rgb <1,1,0>
        color rgb <0,1,1>
        scale 0.3
#declare pig=pigment {
      checker
      pigment {pig1}
      pigment{pig2}
      warp { turbulence 0.2}
box {<-1,-1,-1>,<1,1,1> pigment {pig}}
in this example, I create 2 checker pigments and I join them in another
checker. Then I warp the whole pigment. The big checker is deformed and so
are the 2 inner checkers (pig1 and pig2).
What if I would have pig1 and pig2 not deformed and the edge between them
deformed ?
Thanks for your answer
Subject: Re: textures and warp
Date: 22 Apr 2006 12:21:16
Message: <444a57fc@news.povray.org>
> deformed ?
#declare TurbCheckerFunc = function { pattern { checker turbulence .2 } };
  function { TurbCheckerFunc(x, y, z) }
  pigment_map { [0 pig1] [1 pig2] }
Date: 22 Apr 2006 17:06:03
Message: <444a9abb@news.povray.org>
I would do it this way (untested code):
      pigment_pattern {
            checker
            <0,0,0>
            <1,1,1>
      pigment_map {
            [0 pig1]
            [1 pig2]
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Apr 2006 04:37:34
Message: <444b3cce@news.povray.org>
Yeah ! I wanted 1 method and I have 2 !!!!!
For the second method, it works but you forgot the words color rgb in the
checker definition.
Thanks for both of you
news:444a9abb@news.povray.org...
>       pigment_pattern {
>             checker
>             <0,0,0>
>             <1,1,1>
>       pigment_map {
>             [0 pig1]
>             [1 pig2]
>  - Slime
