POV-Ray : Newsgroups : povray.newusers : Re: How can I change Final_Frame in a .pov-script? Server Time
14 Mar 2026 13:34:50 EDT (-0400)
  Re: How can I change Final_Frame in a .pov-script? (Message 1 to 1 of 1)
Subject: Re: How can I change Final_Frame in a .pov-script?
Date: 25 Jan 2006 13:57:26
Message: <43d7ca16$1@news.povray.org>
Aksel wrote:
> Anyone who knows how to change the "Final_Frame"-variable in a .pov-script?
> My program reads the number of frames together with an array of positions
> and orientations of the object I animate from a text file. The number of
> frames may vary depending on which simulation (in Matlab) I have performed
> with the object. I do not use the 'clock' variable if that is of any
> importance.
You cannot change 'the "Final_Frame"-variable in a .pov-script'. You need to
set this either in the scene's INI file or on the command-line. using this
option is detailed in documentation.
If you are a new users to POV-Ray, I would strongly recommend reading the
documentation first, then ask remaining questions in either povray.general
or povray.newusers .
	Thorsten
