POV-Ray : Newsgroups : povray.newusers : Two questions Server Time
15 Jun 2026 07:07:01 EDT (-0400)
  Two questions (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Two questions
Date: 11 Oct 2005 18:10:04
Message: <434c383c@news.povray.org>
news:434bd3b7$1@news.povray.org...
> I've been using povray for a couple of weeks now. I've got
> two questions which have been bedeviling me.
> 1) Is it possible to set up rendering so that the resulting png has a
> transparent background?  I've tried both
Try:
Output_Alpha=On
in your ini  file
HTH
Marc
Date: 11 Oct 2005 19:26:34
Message: <434c4a2a@news.povray.org>
Rick DeNatale nous apporta ses lumieres en ce 2005-10-11 10:59:
> background { rgbt <0,0,0,1> }
> and
> background { rgbt <1,1,1,1> }
> but when I look at the result in the Gimp, the background seems to be
> black or white respectively.  I've googled and searched these fora but I
> can't seem to find the answer.
> 2) I'm modelling a Mercury spacecraft, which I want to put in low-earth
> orbit, and I'm having problems with the lighting. The light sources
> would be the Sun and the Earth. I've tried a parallel light source for
> the sun, and a large white sphere out of view for the Earth.  I didn't
> seem to be getting much if any "earthshine" this way, so right now I'm
> using a large area light, but I'm still not happy with the results, is
> there a better way to set up this lighting scene?
Point 1) as Marc said, or you can use +UA on the command line. The text box on the
right of the
resolution drop-list.
Point 2) Place a large sphere with an image_map of the earth where you want the earth
to be and use
radiosity. The default settings could be OK with a recursion_limit set to 1.
It will look like #global_settings{ radiosity{ recursion_limit 1 } }
Without radiosity, you don't get the inter diffuse reflection.
Disc space -- the final frontier!
Date: 12 Oct 2005 09:09:48
Message: <434d0b1c$1@news.povray.org>
 > want the earth to be and use radiosity. The default settings could be
Make sure you use a positive ambient value in the earth's finish for
this to work ;)
HTH,
Florian
Date: 12 Oct 2005 10:16:52
Message: <434d1ad4$1@news.povray.org>
> this to work ;)
> HTH,
> Florian
Thanks all, I'll try those suggestions.
If I place the earth outside of the camera's view, I guess I can just
use a solid color sphere (white or maybe blue) with an ambient value
based on the earth's albedo.
Date: 12 Oct 2005 14:33:49
Message: <434d570d@news.povray.org>
> this to work ;)
This isn't necessary if the sunlight is hitting the earth.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 13 Oct 2005 12:48:58
Message: <434e8ffa@news.povray.org>
>> and
> box on the right of the resolution drop-list.
Not sure what you mean by the resolution drop-list.  I'm using povray on
Linux. I've seen some evidence of a gui front-end on Windows. Is that
what you're talking about?
Date: 13 Oct 2005 17:10:21
Message: <434ecd3d@news.povray.org>
> Linux.
  Was "on the command line" somehow unclear?
Date: 14 Oct 2005 03:09:02
Message: <434f598e@news.povray.org>
Ah, yes of course. Didn't think about that. Would be the more realistic
way anyhow :)
Florian
Date: 14 Oct 2005 17:47:30
Message: <43502772$1@news.povray.org>
Rick DeNatale nous apporta ses lumieres en ce 2005-10-13 12:47:
That's on windows, but the part about the command line option still hold true, just
not in the same
place. It's just that "most" new users seems to be using windows.
Bad spellers of the world UNTIE!
Date: 15 Oct 2005 18:28:42
Message: <4351829a$1@news.povray.org>
>>Linux.
Well +UA on the command line was, but the full statement was:
>The text box on the right of the resolution drop-list.
That second sentence fragment is standing there all by it's lonesome.
