POV-Ray : Newsgroups : povray.newusers : Question with a macro Server Time
10 Apr 2026 03:27:14 EDT (-0400)
  Question with a macro (Message 1 to 3 of 3)
Subject: Question with a macro
Date: 27 Sep 2005 14:23:19
Message: <43398e17@news.povray.org>
I've this blob:
#declare Lipid =
blob {
     threshold 0.5
sphere {
       <0, 5/2, 0>, 2/1.2, 1
       texture { RedTexture }
     sphere {
       <0, -5/2, 0>, 2/1.2, 1
     cylinder {
       <0.8, 5/2, 0>, <0.8, -5/2, 0>, 0.5/1.2, 1
       texture { WhiteTexture }
     cylinder {
       <-0.8, 5/2, 0>, <-0.8, -5/2, 0>, 0.5/1.2, 1
translate <0, 0, 0>
And I've done a macro to place copies from this object and to put them like
a bridge. Now I want to put them like a sphere, I want to follow the length
of a sphere with a radius x.
Is it a way to contain them in a sphere and follow the external contour?
Thanks in advance,
Oleguer
Subject: Re: Question with a macro
Date: 27 Sep 2005 17:26:38
Message: <4339b90e$1@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:43398e17@news.povray.org...
> Hi,
> I've this blob:
> #declare Lipid =
> blob {
>     threshold 0.5
> sphere {
>     sphere {
>     cylinder {
>     cylinder {
> translate <0, 0, 0>
> like a bridge. Now I want to put them like a sphere, I want to follow the
> length of a sphere with a radius x.
> Thanks in advance,
> Oleguer
Hi Oleguer,
I'm not quite clear from your note on the sort of distribution you're trying
for.
The following SDL produces an arc of 'Lipids' and rotates it 360 degrees to
give a spherical surface with a separation of 20 degrees:
#declare Angle=20;
#declare Distance=30;
#local I=0;
#while (I<360)
  #local J=0;
  #while (J<180)
    object {Lipid translate z*Distance rotate <J,0,I> pigment {color 1}}
    #local J=J+Angle;
  #local I=I+Angle;
If you want a more random distribution, then you can use something like the
following:
#local I=0;
#local Seed = seed(1);
#while (I<30)
  object {Lipid
    rotate <rand(Seed)*360,rand(Seed)*360,rand(Seed)*360>   // Randomly
Orient
//    translate z*Distance*sqrt(rand(Seed))
// Randomly Fill
// Distribute on Surface
    rotate <asind(sqrt(rand(Seed))),0,rand(Seed)*360>               //
Randomly Distribute
    #if (rand(Seed)>0.5) scale <1,1,-1> #end
    pigment {color 1}
  #local I=I+1;
sphere {0,Distance pigment {color rgbt 0.95}}
The alternative 'translate', that's commented out, fills the sphere with
your shape rather than just placing a copy on the surface.
If you want a random but uniform distribution then it gets a bit complicated
and there have been quite a few threads discussing various alternative
techniques for doing that.
Hope that helps.
Chris B.
Date: 28 Sep 2005 15:43:14
Message: <433af252@news.povray.org>
Hi Chris,
Yeah, I've done, more or less, your first code.
I'm going to have a look at your second code, it looks interesting.
I will post the doubts later.
Thank you very much.
Oleguer
news:4339b90e$1@news.povray.org...
>> Hi,
>> I've this blob:
>> #declare Lipid =
>> blob {
>>     threshold 0.5
>> sphere {
>>     sphere {
>>     cylinder {
>>     cylinder {
>> translate <0, 0, 0>
>> Thanks in advance,
>> Oleguer
> Hi Oleguer,
> trying for.
> to give a spherical surface with a separation of 20 degrees:
> #declare Angle=20;
> #local I=0;
> #while (I<360)
>  #local J=0;
>  #while (J<180)
>    #local J=J+Angle;
>  #end
>  #local I=I+Angle;
> #end
> the following:
> #local I=0;
> #while (I<30)
>  object {Lipid
> Orient
> //    translate z*Distance*sqrt(rand(Seed)) // Randomly Fill
>    translate z*Distance // Distribute on Surface
> Randomly Distribute
>    pigment {color 1}
>  #local I=I+1;
> #end
> complicated and there have been quite a few threads discussing various
> alternative techniques for doing that.
> Hope that helps.
> Regards,
> Chris B.
