POV-Ray : Newsgroups : povray.newusers : Follow the inner contour in a merge Server Time
10 Apr 2026 05:29:01 EDT (-0400)
  Follow the inner contour in a merge (Message 1 to 5 of 5)
Subject: Follow the inner contour in a merge
Date: 10 Aug 2005 04:29:18
Message: <42f9bade$1@news.povray.org>
Hi all,
First I'm going to put a small part of code:
merge{
sphere { <0, 0, 0>, 1
translate -0.5*x
scale <1.2, 0, 0>
sphere { <0, 0, 0>, 0.5
translate 0.7*x
scale <1.4, 0, 0>
After that I've the transformations, the colors and I've clipped_by with a
plane { z, 0} and it's empty using hollow.
Now I want to put a thread following the inside part of the two spheres. The
only way is creating a spline and using it like a function?
Thanks in advance,
Oleguer
Subject: Re: Follow the inner contour in a merge
Date: 10 Aug 2005 05:57:18
Message: <42f9cf7e@news.povray.org>
  No, you have a misconception here.
  'hollow' is related exclusively to media and fog. It has absolutely no
effect whatsoever in anything else than those two things.
  In other words, if you are not using media nor fog, 'hollow' is a no-op.
Date: 10 Aug 2005 07:09:39
Message: <42f9e073$1@news.povray.org>
All right Warp. Thanks for your aclaration.
Oleguer
news:42f9cf7e@news.povray.org...
>                                                          - Warp
Date: 10 Aug 2005 09:49:43
Message: <HXHSqAAbGg+CFwDH@econym.demon.co.uk>
Wasn't it Oleguer Vilella who wrote:
>Hi all,
>merge{
>translate -0.5*x
>scale <1.2, 0, 0>
>translate 0.7*x
>scale <1.4, 0, 0>
Have you considered using torus sections?
If you create a torus so that R1+R2 is equal to the radius of the
sphere, apply any required rotations, translate and scale exactly like
the spherical part that it's following, then difference the other sphere
and plane. Like this
global_settings {assumed_gamma 1.0}
camera {location  <5,0,4> look_at <0.3,0,0> angle 25}
background {rgb 1}
light_source {<-30, -30, 30> color rgb 1}
light_source {<0, 0, 30> color rgb 1}
// Main shape
merge{
   translate -0.5*x
   scale <1.2, 1, 1>
   translate 0.7*x
   scale <1.4, 1, 1>
 clipped_by {plane { z, 0}}
 pigment {rgb x}
// Threads in the large part
#declare N=0;
#declare S=seed(123);
difference {
  union {
    #while (N<20)
      torus {0.98,0.02
        rotate <rand(S),rand(S),rand(S)>*360
      #declare N=N+1;
    translate -0.5*x
    scale <1.2, 1, 1>
   translate 0.7*x
   scale <1.4, 1, 1>
  plane {z,0 inverse}
  pigment {rgb 1}
// Threads in the small part
#declare N=0;
difference {
  union {
    #while (N<10)
      torus {0.48,0.02
      #declare N=N+1;
    translate 0.7*x
    scale <1.4, 1, 1>
   translate -0.5*x
   scale <1.2, 1, 1>
  plane {z,0 inverse}
  pigment {rgb 1}
Mike Williams
Gentleman of Leisure
Date: 11 Aug 2005 03:48:27
Message: <42fb02cb$1@news.povray.org>
Hi Mike,
No, I haven't thought it.
I did it using your suggestion, but I don't need the seed and the rand
rotation because I just want a line folliwing the inner contour of the
object.
So a torus with the radios equal to the radius sphere and applying the
transformations, rotations and scale properly to fit it right.
Thanks for your answer.
Best regards,
Oleguer
news:HXHSqAAbGg+CFw### [at] econymdemoncouk...
>>Hi all,
>>merge{
>>translate -0.5*x
>>scale <1.2, 0, 0>
>>translate 0.7*x
>>scale <1.4, 0, 0>
>>The
> background {rgb 1}
> // Main shape
> merge{
>   translate -0.5*x
>   scale <1.2, 1, 1>
>   translate 0.7*x
>   scale <1.4, 1, 1>
> pigment {rgb x}
> #declare N=0;
> difference {
>  union {
>    #while (N<20)
>      torus {0.98,0.02
>      #declare N=N+1;
>    #end
>    translate -0.5*x
>    scale <1.2, 1, 1>
>   translate 0.7*x
>   scale <1.4, 1, 1>
>  plane {z,0 inverse}
>  pigment {rgb 1}
> #declare N=0;
> difference {
>  union {
>    #while (N<10)
>      torus {0.48,0.02
>      #declare N=N+1;
>    #end
>    translate 0.7*x
>    scale <1.4, 1, 1>
>   translate -0.5*x
>   scale <1.2, 1, 1>
>  plane {z,0 inverse}
>  pigment {rgb 1}
> Mike Williams
