POV-Ray : Newsgroups : povray.newusers : Cut a sphere Server Time
18 May 2026 02:36:29 EDT (-0400)
  Cut a sphere (Message 1 to 6 of 6)
Subject: Cut a sphere
Date: 31 Jul 2005 09:34:32
Message: <42ecd368$1@news.povray.org>
Hi all,
I've done this object:
merge{
    sphere { <0, 0, 0>, 1
      translate -0.5*x
    sphere { <0, 0, 0>, 0.5
      translate 0.5*x
    scale <1.5, 0, 0>
    pigment { rgbf <0.9, 0.9, 0.9, 1> }
    rotate <0, 0, 0>
translate <0, 0, 0>
scale 5
clipped_by { plane { z, 0 }
And I want to cut it, to do it I used a "clipped_by" with a plane, but I
think I'm wrong.
I want to cut the object and then I want to put objects inside. So, I want
to have it "empty". I don't know if the method that I'm using will work
properly.
All helps will be welcome.
Oleguer
Subject: Re: Cut a sphere
Date: 31 Jul 2005 10:05:42
Message: <42ecdab6@news.povray.org>
Maybe something like this?
merge{
translate -0.5*x
translate 0.5*x
scale <1.32, 0, 0>
rotate <0, 0, 0>
translate <0, 0, 0>
scale 5
clipped_by { plane { y, 4 } }
hollow on
interior_texture { pigment { rgbf <.9, .9, .9, 0.8> } }
Oleguer
news:42ecd368$1@news.povray.org...
> Hi all,
> merge{
>      translate -0.5*x
>      translate 0.5*x
>    scale <1.5, 0, 0>
>    rotate <0, 0, 0>
> translate <0, 0, 0>
> scale 5
> think I'm wrong.
> properly.
> Regards,
> Oleguer
Date: 31 Jul 2005 14:53:22
Message: <42ed1e22@news.povray.org>
Oleguer Vilella nous apporta ses lumieres en ce 2005-07-31 08:32:
> Hi all,
> merge{
>       translate -0.5*x
>       translate 0.5*x
>     scale <1.5, 0, 0>
>     rotate <0, 0, 0>
> translate <0, 0, 0>
> scale 5
> think I'm wrong.
> properly.
> Regards,
> Oleguer
As it is, it "looks" empty, if you put some rotation to the whole object, after the
clipped_by.
Removing the filter and using interior_texture shows that clearly, but it have NO
thickness.
What I'd do is this:
difference{
	merge{sphere{0,1 translate -0.5*x}//0,1 = <0,0,0>,1
		sphere{0,0.5 translate 0.5*x scale<1.5,1,1>}//get rid of warning about scaling by 0
		}//exterior part
	sphere{0,0.9 translate -0.5*x}//change the 0.9 and 0.4 to set the thickness of the
side
	sphere{0,0.4 translate 0.5*x scale<1.5,1,1>}//iner "hollow"
	box{<-2,2,0>,<2,-2,-2>}//cut away unneded part
	pigment{rgbt 1}// no surface colour
	interior{ior 1.5 //glass, optionaly add some dispersion, but very subtle effect
		fade_color rgb 0.9//make the material coloured in it's mass
		fade_distance 0.1//adjust to your taste
		fade_power 1001//use exponential fading
Date: 31 Jul 2005 15:12:39
Message: <42ed22a7$1@news.povray.org>
Hi Alain,
Yeah, you've used a box instead of a plane. Why?
Oleguer
news:42ed1e22@news.povray.org...
>> Hi all,
>> merge{
>>       translate -0.5*x
>>       translate 0.5*x
>>     scale <1.5, 0, 0>
>>     rotate <0, 0, 0>
>> translate <0, 0, 0>
>> scale 5
>> think I'm wrong.
>> want to have it "empty". I don't know if the method that I'm using will
>> work properly.
>> Regards,
>> Oleguer
> after the clipped_by. Removing the filter and using interior_texture shows
> that clearly, but it have NO thickness.
> difference{
> scaling by 0
> }//exterior part
> thickness of the side
> effect
> Alain
Date: 31 Jul 2005 22:09:06
Message: <42ed8442$1@news.povray.org>
Oleguer Vilella nous apporta ses lumieres en ce 2005-07-31 14:10:
> Hi Alain,
> Regards,
> Oleguer
I tend to use a box when doing difference, I could use a plane{-z,0} and get the same
result. I
could also have used an intersection with a plane{z,0} or a box extending the other
way as in my sample.
Date: 1 Aug 2005 02:14:14
Message: <42edbdb6@news.povray.org>
Yeah, all right.
Thanks,
Oleguer
news:42ed8442$1@news.povray.org...
>> Hi Alain,
>> Regards,
>> Oleguer
> get the same result. I could also have used an intersection with a
> plane{z,0} or a box extending the other way as in my sample.
> Alain
