POV-Ray : Newsgroups : povray.newusers : Rand and animation Server Time
20 Mar 2026 15:53:21 EDT (-0400)
  Rand and animation (Message 1 to 6 of 6)
Subject: Rand and animation
Date: 12 May 2005 19:30:40
Message: <4283e720$1@news.povray.org>
I am having a problem getting rand to work properly with an animation.
Basically, I'm trying to make the intensity of a light source to flicker
randomly.  In all cases I have a variable which is used in an if
statement to make either a "low" or "high" intensity.  In all cases I
assign a value to a variable "flicker", and use this variable as the
input for rand.  I've tried the following:
1) #declare flicker=seed(clock); . . .
    #if (rand(flicker)>0.5)
       make bright light
    #else
       make dim light
When I do this I get all but the last frame dim.  If I seed(clock*100) I
get the opposite (all frames bright but the last one).
2) #declare flicker=seed(x);, the rest the same as above
In this case I get all dark or all light depending on the value I put in
as x.
I've tried moving the #declare to the .ini file, but this creates an error.
What I think is happening is that the seed for the rand function gets
reset each frame, so I essentially end re-starting the rand function
each time.  Is there a work-around?
thanx
Bryan
Subject: Re: Rand and animation
Date: 13 May 2005 00:45:51
Message: <42843104.EAE460A7@arkady.demon.co.uk>
> randomly.
How about something like:
    #if (f_noise3d(clock*50,0,0)>0.5)
       make bright light
    #else
       make dim light
Bernard
Date: 13 May 2005 03:09:16
Message: <LSNBLCANKFhCFwqt@econym.demon.co.uk>
>       make bright light
>    #else
>       make dim light
>    #end
>as x.
>thanx
>Bryan
The mathematics of pseudo-random numbers is arranged so that consecutive
numbers in each random stream have good randomness.
When you do (2), you're asking for the first random number from the same
stream, which isn't random at all.
When you do (1), you're asking for the first random number from
different streams that have seeds that follow a simple pattern, which
may well not be very random.
The ideal situation would be to pick one stream, and take consecutive
numbers from that stream. This can be achieved by re-seeding the stream
with the same seed and then discarding a number of entries from that
stream corresponding to the current frame_number. Like this:
#declare flicker=seed(1234);
#declare N=0;
#while (N<frame_number)
  #declare junk=rand(flicker);
  #declare N=N+1;
Mike Williams
Gentleman of Leisure
Date: 13 May 2005 05:03:36
Message: <42846d68$1@news.povray.org>
What I usually do: seed(frame_number). Note that seed wants an integer, so
using "clock" as seed will get you the value "0" most of the time, and
strangely enough, in that pseudo-stream, the first random number always is
"0".
The second version (seed(x)) will always return the same first random-value,
so no surprise there that all frames will look the same.
Rand is a pseudo-random stream, so the same seed will *always* yield the
same stream of random-numbers.
Tim
"Tim Nikias v2.0"
Date: 13 May 2005 05:05:40
Message: <42846de4$1@news.povray.org>
I think the problem lies within seed(clock) in this case. Until the last
frame, clock is a value below 1, so it will use the seed "0", hence he gets
the same outcome every frame until the last, where clock is 1 and the seed a
different one. It would help to multiply clock with 100 or 1000, or use
frame_number as the seed.
"Tim Nikias v2.0"
Date: 13 May 2005 13:09:29
Message: <4284df49$1@news.povray.org>
> "0".
> Regards,
> Tim
Using the seed(frame_number) worked perfectly!  Thanx Tim (and everyone
else) for your help.
Bryan
