POV-Ray : Newsgroups : povray.newusers : Blobs Server Time
16 Jun 2026 11:39:16 EDT (-0400)
  Blobs (Message 1 to 7 of 7)
Subject: Blobs
Date: 29 Jan 2005 12:27:02
Message: <41fbc766@news.povray.org>
Hi all,
I have done this code:
#declare lipid =  union {
blob{  threshold 0.1
sphere {<0, 0, 0>, 2 ,1 texture {pigment { color Red }finish { ambient 0.2
diffuse 0.8 phong 1 }}}
#macro Make_Stuff (Stuff,How_Many)
#local Ample=-12;
#while (Ample<How_Many)
object{Stuff  rotate <0,0*Ample,0> translate<3*Ample,9*cos (Ample/8),0> }
#local Ample=Ample+1;
#declare layer = union {Make_Stuff (lipid,100)}
global_settings { max_trace_level 29 }
#macro Make_Many (Stuff,How_Many)
#local Fons=0;
#while (Fons<How_Many)
object{Stuff  translate <0,3*sin (Fons/8),3*Fons> translate <10, -20, 30>}
#local Fons=Fons+1;
union {Make_Many (layer,50)}
How can I unife all the spheres?
Thanks in advance.
Oleguer
Subject: Re: Blobs
Date: 29 Jan 2005 21:15:00
Message: <41fc4324$2@news.povray.org>
Oleguer Vilella nous apporta ses lumieres en ce 2005-01-29 11:25:
> Hi all,
> blob{  threshold 0.1
> #local Ample=-12;
> #end
> #end
> #local Fons=0;
> #local Fons=Fons+1;
> #end
> #end
> Thanks in advance.
> Oleguer
You can start by removing the union and blob from the lipid object:
#declare Lipid=sphere{0,2,1 texture{pigment{color Red}finish{ambient 0.2 diffuse 0.8
phong 1}}}
Then, in the Layer object:
#declare Layer=blob{thresshold 0.1 Make_Stuff(Lipid,100)}
I did not try it.
Note: it's beter to *always* start any user defined identifier with a capital letter,
it prevent any
name clash with built-in reserved name, present and future. Who know if a future
fersion could use
"layer" for some purpose?
Subject: Re: Blobs
Date: 30 Jan 2005 01:15:28
Message: <sA9oPCA0tH$BFwS0@econym.demon.co.uk>
Wasn't it Oleguer Vilella who wrote:
>Hi all,
Do you mean like this?
#macro Make_All(N,M)
  blob {threshold 0.1
  #local Ample=-12;
  #while (Ample<N)
    #local Fons=0;
    #while (Fons<M)
      sphere {<0,0,0>, 2, 1
      #local Fons=Fons+1;
object {Make_All(100,50)
    finish { ambient 0.2 diffuse 0.8 phong 1 }
Mike Williams
Gentleman of Leisure
Subject: Re: Blobs
Date: 30 Jan 2005 06:15:11
Message: <41fcc1bf@news.povray.org>
Hi Alain,
Your code gives me an error. It says: "No matching } in 'sphere',, found
instead".
This part of code is:
diffuse 0.8 phong 1}}}
Why this error? I have closed de all the }
Understood that's is better declare the identifiers with a capital letter.
Thanks a lot for reminder me that.
Hi Mike,
Thanks for your help Mike, but that's not what I was looking for. I'm
traying to unify all the spheres to obtain an uniform membrane.
Thanks all the helps,
Oleguer
news:41fc4324$2@news.povray.org...
>> Hi all,
>> blob{  threshold 0.1
>> 0.2 diffuse 0.8 phong 1 }}}
>> #local Ample=-12;
>> #end
>> #end
>> #local Fons=0;
>> 30>}
>> #local Fons=Fons+1;
>> #end
>> #end
>> Thanks in advance.
>> Oleguer
> I did not try it.
> capital letter, it prevent any name clash with built-in reserved name,
> present and future. Who know if a future fersion could use "layer" for
> some purpose?
> Alain
Subject: Re: Blobs
Date: 30 Jan 2005 09:15:57
Message: <41fcec1d$1@news.povray.org>
Oleguer Vilella nous apporta ses lumieres en ce 2005-01-30 05:13:
> Hi Alain,
> instead".
> Hi Mike,
> Oleguer
OK, the syntax used is that of a sphere as a blob component, not a regular sphere. You
probably need
to replace that by a macro, or place it inside the Make_Stuff macro.
Subject: Re: Blobs
Date: 31 Jan 2005 11:41:20
Message: <J9lazIApnj$BFwVN@econym.demon.co.uk>
>Hi Mike,
Sorry for the late response. I've been unable to establish a link to the
pov newsserver for a few days.
Well, once you've got all the blob components in a single blob object
you can adjust the threshold value, and the strength and radius of the
individual blobs, and the separation between the blobs (like #local
Fons=Fons+0.5), so that they blob together into a bumpy membrane. You
can't do that with your original version because each sphere is a
separate blob object.
Alternatively, you could discard the blobs altogether and use the same
cos and sin waves to drive an isosurface function, which will give you a
perfectly smooth membrane that has exactly the same shape.
#declare  F = function {y - 9*cos(x/3/8) - 3*sin(z/3/8)}
#declare Thickness=1.5;
isosurface {
  function { abs(F(x,y,z)) - Thickness }
  max_gradient 2
  contained_by{box{<-36,-20,0><300,20,150>}}
  pigment {rgb x}
  translate <10,-20,30>
If you want, you can put fake blobs back into the isosurface as follows.
The "x+z" and "z-x" bits rotate the fake blobs by 45 degrees, otherwise
the leopard pattern has a diagonal pattern.
camera {location  <150,150,-150> look_at <150,50,0> }
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#include "functions.inc"
isosurface {
  function { abs(F(x,y,z)) - Thickness - f_leopard(x+z,0,z-x) }
  max_gradient 2
  pigment {rgb x}
Mike Williams
Subject: Re: Blobs
Date: 1 Feb 2005 15:07:52
Message: <41ffe198@news.povray.org>
Hi Mike,
Don't worry, it isn't a delay.
Thanks for your help. All understood now. I didn't know the leopard function
and I now I know it.
Oleguer
news:J9lazIApnj$BFwVN@econym.demon.co.uk...
>>Hi Mike,
> isosurface {
>  max_gradient 2
>  pigment {rgb x}
> background {rgb 1}
> isosurface {
>  max_gradient 2
>  pigment {rgb x}
> Mike Williams
